Just took a outdoor ride with Garmin Edge 130. When I tried to import the FIT file into WKO5 by drag the FIT file from file explorer to the window of WKO5,the workout didn't appear in it.
Then I checked the time of the FIT file and found the time is also correct.(The FIT file was successfully imported into Garmin Connect by sync)
Is the FIT file generated by Edge 130 compatible with WKO5 or any other training analysis software?
Or any idea to the solution?
Thanks!
