Hi Everyone,
I have an Edge 130 I purchased last June that just seems to have lost its mind in the last day. I had it out for a few rides the last few weeks and everything went fine. I wanted to compare my new power meters to my Saris H3 power readings, so I put the bike on the trainer, shut off GPS on the Edge and did a long ride indoors recording both with Zwift and with the Edge 130. That went fine and I got the data I needed.
I hooked up the Edge to charge it last night and disconnected it when I got up this morning. I went in to turn GPS back in and it wouldn'tt turn on. I run through the steps, and no matter what I pick, the Edge returns to the previous menu and GPS is still off. It acts like I hit the return button instead of the select button (and I am NOT doing that - I'm certain). Now, even though it says GPS is off in the menu, I noticed it said "GPS Ready" at one point on the main screen...so I'm like, what? I decided to go walk around with it for a minute and record something to see what I actually go, and that's when I noticed all my data page setups were gone.
I haven't really used it, so I'm not sure how that would have happened, but I went about setting one back up and when I was done went to do the walk again, and the data page I just set up isn't there. I tried setting up a simple one-item page and it's not saving them.
Is my Edge borked? I will probably reach out to support since it's less than a year old, but I'm not sure what else to do. I've shut it off and restarted it several times and nothing seems to snap it out of its funk.
Any suggestions on things to try?
Thanks,
Gary
