Is there any official response from Garmin on the obviously rampant problem of poor battery life of the Edge 130?
Just changed the battery for my and my wife's Garmin 130 devices using this 400mAh from Ali: https://aliexpress.ru/item/32331217147.html?_ga=2.222079512.1448944204.1649159448-737075485.1649159448&sku_id…
There is space in the case for a bigger battery, Garmin could have utilised that in the 130 plus AND offer an upgrade for the older 130. Missed opportunity.
I juste swap my edge 130 with 370 mah aliexpress battery,, huge upgrade for 2.5€ shipped !!!
There are various threads on this. Garmin doesn't care. I wonder if the new Edge 130 "Plus" is any better for battery life? I went out on one of my biggest rides of the year this past weekend, a Ride to Defeat ALS fundraiser. Just before hour 10, I noticed my screen was blank. It was done, and I still had nearly 2 hours to go. Now my Strava post is so sad, with a big straight line from where it died to the parking lot where I plugged it back in at the end of a long day.
Garmin should have done this right, they should have put a bigger battery in, BUT... They could also mitigate some of the damage. They could satisfy a lot of us by offering a twist-on battery pack that in turn clips into the Garmin mount. I know they have it for other models. Yeah, it would need a short cord to work, but I could live with that. I'd be willing to spend another $40 for an external battery for the real cold days and to use the back-light more during night rides.
Garmin is disappointing, can't argue that. They host these forums to glean what they can about customer sentiment to steer new model introductions, but don't step in with any solutions to problems with existing units. The most we can hope for is perhaps this prompts some software upgrades that might not otherwise come. Maybe someday my elevation graph will work while following a course...
What a joke! People buy the 130 because it is small. Also the usb port is at the back of the unit. How are people going to use the Garmin battery pack with this unit?
First of all, the battery is too small.
But do you ride at night?
The 130 display does not need backlight during the day.
Riding with backlight on is heavy on all devices, not only on the 130.
You could say Backlight = Backlight, whether the device is big or small.
However bigger devices have a bigger battery, so the impact of the backlight is smaller on bigger devices.
My Etrex has 2800mAh batteries, and has no problem with backlight.
The same Etrex lasted 28h(!) outside in the freezing cold (GPS+Glonass and ANT enabled - bcklight off)
