Unable to Power On Device
I tried to turn on my Edge 130 after a few months (out due to injury) and it's not powering on. The only time it turns on is when it's connected to a power source. While on, it shows that it's at 100% battery. Does anyone have any experience with solving such an issue?
  • I'm having exactly the same problem: 100% battery, but will not power on with switch on the top left. But my Edge 130 has behaved this way since new. I have not been able to use it. I have just updated to the latest firmware (3.2) but this was no help; still cannot get mine to turn on.
  • Try doing reset
    Non-prompted Non-Vol Clear - Clears NV and deletes all FIT files including Activities, Courses, Workouts etc. (takes the device back to defaults).
    • With the unit powered off, hold the up and down buttons and power it on
    • Release the up button after the 1[SUP]st
    • [/SUP] beep.
    • Release the down button after the 2[SUP]nd
    • [/SUP] beep.
    • The non-vol clear was successful if the device finishes powering up and goes to the setup wizard.
    Try doing reset
    • [/SUP] beep.
    • [/SUP] beep.
    I just tried to do but can't get past step 1. I suppose that there's something wrong with the battery? Is there anything else I can do? I just charged the Edge 130 overnight but still nothing.
  • Thanks for the quick reply Alex. I was able for follow your advice (It was a little tricky to plug the change cable in whilst holding the up / down arrows and needed an assistant :-)). The reset was succesful. I was able to connect to my Phone and do a complete new set-up - but only when the charge cable was connected.
    However as soon as I remove the chage cable the divice switches off instantly and the screen dies. There was no shutdown sequence as I am familiar with for other Edge devices. When I try to power the device back on there is no effect - it remains dead.
  • Chaks -- you will need to get help holding the up / down arrow - and then whilst holding them get a freind to plug in the power charge cable at the back. Tricky, but I managed.
    However even after this the problem remains as per my previous post.
  • Sounds like you will need to contact customer services and get the units replaced.
  • Hi Guys, Just an update on my power start up problem. Garmin contacted me over the phone and replaced the unit.
    Garmin's responce on this occation was quick and very efficient. I have been SUPER impressed! We often find cause to complain about poor customer service, but I thought I should acnowledge great service as well.
  • Hi, I have exactly the same problem with a Garmin Edge 130 straight out of the box. I contacted Garmin via email. After 1 week still no response... only a recieved message confirmation.  So on my account not a great service yet... (via phone they have very limited possibilities to reach them since i do not like to call a customer service when I am working.
    My garmin edge 130 will not hold a charge. The bars are all white after 12 hours. I was able to get three bars today, but when i unplugged the unit the bars went back to white indicating no charge.
    Brand new unit right out of the box.  Same symptoms as described.  The reset worked exactly as described.  Thanks for the tip
