Firmware 3.x / 4.0 feature requests here
I'm really happy with firmware 3.0 - almost perfect for me. But I hope it won't be the last update. Since I could't find a main topic collecting all requests for future updates: here you go - please reply with more requests/bugs.
FEATURE REQUESTS
  • adjust auto pause speed (topic here)
  • remove the scrollbar (topic here)
  • add whatsapp / messenger notifications (topic here)
  • quick reply messages by pressing single button with predefined message like "I'm ok"
  • add temperature data field (topic here)
  • change auto lap duration (topic here)
  • add etap / di2 (topic here)
  • Battery level in continuous percentage again
  • Backlight Off setting, that would then allow a press of the power button to toggle the backlight on and off
  • auto power on when sensors get active
  • auto start recording the ride when the sensors report movement / "movement detected" warning
  • total ascent in feet if set to "statute"
  • L/R Power Balance / AVG would be nice for Vectors
  • Naming sensors
  • Vertical Speed (like VS30 in Edge 500) - it's just a calculation of data that already exist
  • Manual Calibration of the Altitude before Ride (topic here)
  • option to delete all logs at once (topic here)
  • improve the UI speed (e.g. pressing stop to having the menu appear seems very sluggish)
  • option to turn off messages like "Press and Hold Top Button to Access Menu", "Backlight Timeout is set to on ....." and "Wait while GPS while cycling outdoor"
  • Larger numbers/characters in fields that cover half the screen. Lots of dead space here: https://media.dcrainmaker.com/images...4/DSC_3616.jpg
  • Disable/Remove Weather and Notifications (Topic)
  • Map: allow user to toggle between north up and direction of travel up.
BUGS
  • Zoom Map In/Out - value can not be changed permanently (Bug? Topic here)
  • Full german translation (new GERMAN.LN3-File)
  • wrong elevation? (topic here and here)
  • BLE speed/cadence paired but not working (Topic)
    Bug: Power Off = Crash & Reboot.
    Feature request:
    +1 for:
    • ! Backlight Off setting, that would then allow a press of the power button to toggle the backlight on and off
    • !! Larger numbers/characters in fields that cover half the screen. Lots of dead space here: https://media.dcrainmaker.com/images...4/DSC_3616.jpg
    Garmin-Matthew will there be a new firmware at some point? And are the developers aware of this thread? Thanks! Tom
  • tomha - We will release future updates to the Edge 130 and we do report issues to our developers that come from the forums.
    Hi,
    I want to update my Edge 130 manually. Do you know where I can download the firmware as an gcd-file? http://gawisp.com/perry/ doesn't seem to host the firmware...
    Many thanks!
    I just received my 130 and my main use case for buying one was for the Extended Display option. When paired with my watch, however, the top 2 data fields are mandatory and cannot be changed (timer and lap time). Can the firmware please be updated to allow full control over these data fields?
  • I just received my 130 and my main use case for buying one was for the Extended Display option. When paired with my watch, however, the top 2 data fields are mandatory and cannot be changed (timer and lap time). Can the firmware please be updated to allow full control over these data fields?
    If it is mandantory for you - take the chance and send it back. Nothing has happened since 3.00 rollout. I do not expect anything to get soon. Garmin does not focus on such "cheap" devices.
  • A feature request rather than a firmware change.
    A redesigned usb cover.
    My cover snagged when using the Garmin 1000 mount, but spotted it and managed to reseat it. However, a week later I must have snagged it again because now it is missing. The rubber cap sat slightly proud of the case, hence it caught the mount when it was twisted on.
    I'm not sure if it is possible to get a replacement?
  • JanSwanwick - We do offer a replacement USB cover for the Edge 130. I would recommend contacting Product Support to get a replacement.
    Duplicate post but wanted to put it in this thread, as well:
    Installed FW 3.20....let the whining begin :p So manually inputting elevation number is the best solution and only option we can get here? How will this work with multiple starting points with different elevations? Is auto calibration overridden/eliminated now?
    Is the erratic battery level indicator back with 3.2?
    Fully charged the unit on my laptop and the next time I switched on the edge it was showing 80% (actually 4 bars as we still don’t get %). Holding the menu button to access menu items then returning to home screen saw it back at 5 bars.
    Went for for a ride with fully charged unit, after 25 minutes it showed 4 bars.
    Good to see the fix for segments when navigating courses and we now have a means of calibrating the altimeter. In fixing these have Garmin managed to re introduce an old bug? Anyone else seeing this?
