Changes made from version 28.20 to 28.33:
- Support for Rally 110 and 210 power meters, including Force data and Pedal IQ smart calibration alerts
- Improved compass performance while creating timing gates
- Fixed issue where turn instruction icon was incorrect for certain roundabouts
- Fixed potential inReach Remote issues after losing connection
- Fixed issue where custom maps wouldn't draw
- Fix issue with audio prompts not playing in some cases
- General improvements to device stability and addressed various minor bugs
Changes made from version 13.14 to 28.20
- Improved ClimbPro climb detection and resume functionality
- Fixed nutrition and hydration alert functionality
- Added triathlon event and workout support
- Added Short-Term Ephemeris (GPES) support for faster GPS acquisition
- Added option to clear temporary files including ephemeris data
- Improved Lock on Road functionality to prevent incorrect positioning
- Fixed radar bar halo not appearing while turn prompt visible
- Fixed auto-brightness not working after wake from sleep
- Fixed home page activity profiles to correctly display the distance during activities
- Fix workout data screen customizations being reset after powering off the device
- Added trail difficulty tracking for mountain biking activities
- Added timing gates feature for creating and tracking custom timing segments with improved split display
- Added Enduro MTB and Downhill MTB activity profiles with specialized data screens
- Enhanced ForkSight feature with improved touch controls and trail selection
- Enabled 5Hz GPS recording by default when descending on the new Enduro MTB and Downhill MTB activity profiles for improved tracking
- Updated Connected POI glance layout to prevent text overlap
- Fixed workout duration picker not scrolling with touch
- Increased available space for Connect IQ apps on Edge 1050
- Overall stability improvements and minor bug fixes
Changes made from version 13.13 to 13.14:
- Fixed freezes and crashes while navigating or viewing the map page
- Fixed pairing issues with inReach Mini 2
Changes made from version 12.18 to 13.13:
- Added animations to various performance graphs, gauges, and glances
- Enabled software updates over BLE
- Added presets for Campagnolo 13-speed groupsets
- Added support for Varia Vue SD card reformatting
- Added ability to save a course in the reverse direction
- Added an 8-second timeout to the Spectator Messaging prompt
- Added error prompt for failed software update
- Improved altimeter accuracy with barometer outlier rejection
- Improved user experience for pairing secure BLE sensors
- Improved performance when loading large courses
- Improved gear preset selection to automatically apply a valid configuration when a shifting system reports a non‑standard gear count
- Improved handling of missing elevation data in elevation graphs
- Improved Map Manager error handling
- Improved Varia Vue support
- Fixed issue where dynamic glance would not update with the current Garmin Coach workout
- Fixed issue where dynamic glance does not update unless device is rebooted
- Fixed issue where ClimbPro could show different lengths for the same climb
- Fixed issue where ClimbPro datascreen was incorrectly disabled
- Fixed issue where Garmin Coach would incorrectly show a rest day after a workout was completed
- Fixed issue preventing Garmin Coach 'Improve Fitness' plans from syncing to the device
- Fixed issue that could prevent activity data from saving
- Fixed issue with incorrect time remaining in workouts when activity is paused
- Fixed issue where the 'Stop Navigation' option could disappear too quickly
- Fixed battery status icon inconsistency in battery low warning prompt
- Reordered power and HR zones to match Garmin Connect (high to low)
- Fixed GroupRide glance showing 0 riders
- Fixed issue with sensors displaying improper name
- Fixed duplicate data screen entry when adding new data screen
- Fixed manual Wi‑Fi sync incorrectly reporting sync failure
- Fixed POI not showing “add” icon in Course Creator
- Fixed missing tone when connecting new sensor
- Removed start timer reminder tone on non-data screens
- Fixed issue with Accept button in connection prompts
- Fixed issue with pairing third‑party power meters via Bluetooth
- Fixed segment deletion in settings menu
- Fixed color persistence on power off page options
- Fixed issue in course creator where zooming in/out triggered other actions
- Fixed issue where language picker gets stuck in infinite scroll
- Fixed long segment name clipping
- Updated format of custom alerts to new layout
- Fixed issue with location offset in China when transferred from other devices
Changes made from version 12.17 to 12.18:
- Connect IQ bug fixes and improvements
Changes made from version 12.16 to 12.17:
- Fixed issues with enabling/disabling bike alarm
- Fixed custom data screens being duplicated in certain cases
Changes made from version 11.24 to 12.16:
- Added the ability to view Garmin Coach running and strength workouts within Edge calendars (supporting wearable required)
- Added the ability to view multiple workouts scheduled on the same day within Edge calendars
- Fixed Altimeter calibration menu night mode issues
- Centered GroupRide rider list around user
- Fixed gear details showing invalid data and gear data fields not populating data correctly for eBikes
- Added connection type information for paired sensors
- Fixed nutrition/hydration tracking if the unit is power cycled in the middle of an activity
- Fixed pause during the update process before the unit reboots
- Added support for HRM 200 pairing and data
- Added ability to update Garmin power pedal scale factors with accuracy of 4 decimal places
- Fixed issues with third-party workouts not syncing to device
- Fixed climb pro lines being too thick as you zoom out on the map
- Fixed intensity minutes glance displaying incorrect values
- Improved the algorithm used to calculate the workout execution score
- Fixed crash when cancelling Garmin Share transfer
- Fixed various bugs and crashes
- Added light color mode glances for glance list
- Fixed max speed/cadence getting cut off in certain graphical data field configurations
- Fixed dark mode spectator messages having invisible text
- Fixed graphical data field selection on GCM for data screen setup
- Fixed bugs with map icons
- Fixed electronic shifting data field sizing
- Fixed CIQ glances from having missing backgrounds and added light mode CIQ glance backgrounds
Changes made from version 10.19 to 11.24:
- GroupRide
- Fixed GroupRide dynamic glance failing to update with finished ride data.
- Fixed GroupRide awards getting reset after a power cycle.
- Garmin Coach
- Fixed an issue where the dynamic area would not update with the Garmin Coach workout.
- Fixed Garmin Coach workout not showing as complete in the Garmin Coach glance.
- Fixed issue where device wouldn't show some Garmin Coach plans in the Garmin Coach widget.
- Fixed an issue where Garmin Coach workouts wouldn't sync.
- Updated the jump tone to make it easier to hear.
- Prevented device from entering MTP mode when it is turned off, but Bike Alarm is active.
- Removed legacy FTP test.
- Lactate Threshold estimates are applied automatically after training with heart rate.
- Added new compass data field.
- Added new map data field.
- Added 10s/30s average power graphical data field
- Added a confirmation message for successful manual altimeter calibration.
- Fixed double radar overlay in the Connect IQ Store.
- Fixed pairing to inReach Messenger Plus.
- Fix map track-line issues.
- Fixed phone connectivity issue
- Fixed mismatching navigation arrow and distance to next arrow.
- Muted notifications while bike alarm is set since it was triggering the alarm.
- Fixed issue where elapsed timer would work incorrectly after suspending device during an activity.
- Fixed an issue where record messages would fail to record periodically and leave gaps in the activity file when the phone was connected.
- Fixed overlapping timed alerts failing to alert.
- Fixed recovery heart rate writing to an incorrect field in an activity file so that Garmin Connect would fail to display it.
- Fixed consistency of Climb Pro behavior on looped ride.
- Fixed route recalculation errors after deviating from planned course.
- Fixed issue where a course with a very slow Virtual Partner could crash the device.
- Fixed crash when processing Bluetooth data.
- Added new SRAM gear presets for 13 speed gravel groupsets.
- Fixed issue where screen would display "snow" on power up.
- Updated Shimano STEPS terminology to "Shimano E-bike".
- Fixed ability to use the bell while audio prompts are playing.
- Fixed Back to Course calculation that requires a u-turn.
- Fixed layout of graphical data fields.
- Fix issue where both heart rate and power zones could overlap.
- Fixed Di2 battery data field to update with proper battery level.
- Fixed an issue where the sounds menu settings would fail to save.
- Fixed issue where the weather widget would have valid data but fail to show it.
- Fixed layout of map browsing page to show the map scale when a location is selected.
- Fixed truncation of climb length on climb complete prompt.
- Fixed some text layout issues.
- Fixed grade value acting erratic after a suspend/resume cycle.
- Fixed Stamina Distance to Go units.
- Updated the icon displayed when the Edge is connected to a computer.
- Fixed a crash that could occur on power down.
- Fixed data screens with maps showing the wrong layers.
- Fixed various bugs and crashes.
Changes made from version 10.18 to 10.19:
- Fixed memory leak issue that could cause a crash
Changes made from version 9.11 to 10.18:
- Added Garmin Share. Share your workouts, courses, and waypoints between compatible Garmin devices.
- Added ecosystem-wide Garmin Coach support. Train for an event, achieve a milestone, or improve your fitness with dynamic Garmin Coach training plans for runners and cyclists.
- Added GroupRide awards and climb competitions.
- Added road hazards support. Get alerts for road hazards reported by fellow cyclists and contribute your own edits.
- Added wind and stamina adjustments to Power Guide.
- Added surface type support including on the map, in-ride unpaved road alerts, and post-ride summary.
- Added Wi-Fi map download support.
- Added revamped Course Creator.
- Updated grade algorithm to be much more responsive.
- ClimbPro
- Fixed climb clusters failing to display climb details.
- Fixed an issue where the climb list page could highlight the incorrect current climb.
- Fixed climbs drawing on a course when ClimbPro is disabled.
- Retained the setting for the ClimbPro, Segment, and PowerGuide slider between page uses.
- Added support for India basemap.
- Added gear presets for SRAM 12 speed cassettes.
- Added a QR code to quickly pair a Strava account with Garmin Connect.
- Added search alias support to improve location searching.
- Added course search to the search bar.
- Fixed USB connection detection when coming out of suspend mode.
- Fixed crash that could occur when saving the ride.
- Fixed incident detection countdown timeout notification priority over any other notifications.
- Fixed infinite elevation calibration prompt following a manual calibration.
- Removed tone from elevation calibration prompt.
- Fixed mute toggle interactions on the notifications widget.
- Fixed pausing navigation.
- Improved speed of city search.
- Improved phonetic and hand-writing keyboard input.
- Fixed ride button failing to show after receiving and reviewing a Connected POI.
- Fixed friendly name for phone pairing.
- Fixed issue where hazards in China could appear offset on the map.
- Set minimum backlight level to retain screen visibility after backlight timeout expires.
- Persisted backlight level setting through battery saver enable and disable.
- Fixed battery remaining time estimate not updating when toggling Hide Map option in battery saver menu.
- Fixed display of battery level when it dropped below 5%.
- Fixed small roads on map being drawn too thick.
- Fixed behavior of menus from popping back to previous page to remaining on page after data entry.
- Fixed an issue where British coordinates could not fully be entered with the keyboard.
- Improved layout of post-ride highlights page.
- Fixed various crashes and freezes.
Changes made from version 9.09 to 9.11:
- Improved performance of hazards including fixing an issue where a hazard would not prompt.
- Fixed an issue where Power Guide target could display incorrectly after a climb.
Changes made in version 9.09:
- Updated GNSS firmware to 11.00
- GroupRide Improvements:
- Added descriptions and fixed values for GroupRide awards.
- Fixed issue where GroupRide shared code is lost if consent is required.
- Removed redundant time information in competition results.
- Fixed GroupRide course not downloading and failing to display after a ride.
- Fixed layout of awards list items.
- Fixed awards taking a long time to show up in history.
- Fixed errant climb competition winner when climb doesn't register as a competition.
- Fixed showing start distances for competitions.
- Fixed issue where a hazard would still be visible after a downvote on a ride.
- Added a QR code to quick link to pair a Strava account with Garmin Connect.
- Integrated CIQ glance theme support.
- Fixed crash that could occur when updating Power Guide.
- Fixed crash that could occur when navigating back to start.
- Fixed crash that could occur when using course creator.
- Fixed freeze that could occur during WiFi sync.
- Fixed key press behavior when battery saver display timeout is active.
- Fixed issue where a specific sequence could result in double swiping on timer loop pages.
- Fixed high power consumption on the map page after loading a course.
- Fixed battery saver estimate accuracy.
- Fixed showing the battery was charging when the temperature range was exceeded, and battery was not in a charging state.
- Fixed layout on the segment/climb dual approach prompt.
- Fixed multiple issues with graphical data fields.
- Added highlight to the selected data field.
- Fixed font size for large data fields.
- Added real-time settings menu for voice prompt settings.
- Fixed display of unpaved data in course summary.
- Fixed activity profile odometer not refreshing after a ride.
