Live as of 5/8/25
Changes made from version 12.18 to 13.13:
- Added animations to various performance graphs, gauges, and glances
 - Enabled software updates over BLE
 - Added presets for Campagnolo 13-speed groupsets
 - Added support for Varia Vue SD card reformatting
 - Added ability to save a course in the reverse direction
 - Added an 8-second timeout to the Spectator Messaging prompt
 - Added error prompt for failed software update
 - Improved altimeter accuracy with barometer outlier rejection
 - Improved user experience for pairing secure BLE sensors
 - Improved performance when loading large courses
 - Improved gear preset selection to automatically apply a valid configuration when a shifting system reports a non‑standard gear count
 - Improved handling of missing elevation data in elevation graphs
 - Improved Map Manager error handling
 - Improved Varia Vue support
 - Fixed issue where dynamic glance would not update with the current Garmin Coach workout
 - Fixed issue where dynamic glance does not update unless device is rebooted
 - Fixed issue where ClimbPro could show different lengths for the same climb
 - Fixed issue where ClimbPro datascreen was incorrectly disabled
 - Fixed issue where Garmin Coach would incorrectly show a rest day after a workout was completed
 - Fixed issue preventing Garmin Coach 'Improve Fitness' plans from syncing to the device
 - Fixed issue that could prevent activity data from saving
 - Fixed issue with incorrect time remaining in workouts when activity is paused
 - Fixed issue where the 'Stop Navigation' option could disappear too quickly
 - Fixed battery status icon inconsistency in battery low warning prompt
 - Reordered power and HR zones to match Garmin Connect (high to low)
 - Fixed GroupRide glance showing 0 riders
 - Fixed issue with sensors displaying improper name
 - Fixed duplicate data screen entry when adding new data screen
 - Fixed manual Wi‑Fi sync incorrectly reporting sync failure
 - Fixed POI not showing “add” icon in Course Creator
 - Fixed missing tone when connecting new sensor
 - Removed start timer reminder tone on non-data screens
 - Fixed issue with Accept button in connection prompts
 - Fixed issue with pairing third‑party power meters via Bluetooth
 - Fixed segment deletion in settings menu
 - Fixed color persistence on power off page options
 - Fixed issue in course creator where zooming in/out triggered other actions
 - Fixed issue where language picker gets stuck in infinite scroll
 - Fixed long segment name clipping
 - Updated format of custom alerts to new layout
 - Fixed issue with location offset in China when transferred from other devices
 - General improvements to device stability and addressed various minor bugs
Changes made from version 12.17 to 12.18:
- Connect IQ bug fixes and improvements
Changes made from version 12.16 to 12.17:
- Fixed issues with enabling/disabling bike alarm
 - Fixed custom data screens being duplicated in certain cases
Changes made from version 11.24 to 12.16:
- Added the ability to view Garmin Coach running and strength workouts within Edge calendars (supporting wearable required)
 - Added the ability to view multiple workouts scheduled on the same day within Edge calendars
 - Fixed Altimeter calibration menu night mode issues
 - Centered GroupRide rider list around user
 - Fixed gear details showing invalid data and gear data fields not populating data correctly for eBikes
 - Added connection type information for paired sensors
 - Fixed nutrition/hydration tracking if the unit is power cycled in the middle of an activity
 - Fixed pause during the update process before the unit reboots
 - Added support for HRM 200 pairing and data
 - Added ability to update Garmin power pedal scale factors with accuracy of 4 decimal places
 - Fixed issues with third-party workouts not syncing to device
 - Fixed climb pro lines being too thick as you zoom out on the map
 - Fixed intensity minutes glance displaying incorrect values
 - Improved the algorithm used to calculate the workout execution score
 - Fixed crash when cancelling Garmin Share transfer
 - Fixed various bugs and crashes
 - Added light color mode glances for glance list
 - Fixed max speed/cadence getting cut off in certain graphical data field configurations
 - Fixed dark mode spectator messages having invisible text
 - Fixed graphical data field selection on GCM for data screen setup
 - Fixed bugs with map icons
 - Fixed electronic shifting data field sizing
 - Fixed CIQ glances from having missing backgrounds and added light mode CIQ glance backgrounds
Changes made from version 10.19 to 11.24:
- GroupRide
- Fixed GroupRide dynamic glance failing to update with finished ride data.
 - Fixed GroupRide awards getting reset after a power cycle.
 - Garmin Coach
- Fixed an issue where the dynamic area would not update with the Garmin Coach workout.
 - Fixed Garmin Coach workout not showing as complete in the Garmin Coach glance.
 - Fixed issue where device wouldn't show some Garmin Coach plans in the Garmin Coach widget.
 - Fixed an issue where Garmin Coach workouts wouldn't sync.
 - Updated the jump tone to make it easier to hear.
 - Prevented device from entering MTP mode when it is turned off, but Bike Alarm is active.
 - Removed legacy FTP test.
 - Lactate Threshold estimates are applied automatically after training with heart rate.
 - Added new compass data field.
 - Added new map data field.
 - Added 10s/30s average power graphical data field
 - Added a confirmation message for successful manual altimeter calibration.
 - Fixed double radar overlay in the Connect IQ Store.
 - Fixed pairing to inReach Messenger Plus.
 - Fix map track-line issues.
 - Fixed phone connectivity issue
 - Fixed mismatching navigation arrow and distance to next arrow.
 - Muted notifications while bike alarm is set since it was triggering the alarm.
 - Fixed issue where elapsed timer would work incorrectly after suspending device during an activity.
 - Fixed an issue where record messages would fail to record periodically and leave gaps in the activity file when the phone was connected.
 - Fixed overlapping timed alerts failing to alert.
 - Fixed recovery heart rate writing to an incorrect field in an activity file so that Garmin Connect would fail to display it.
 - Fixed consistency of Climb Pro behavior on looped ride.
 - Fixed route recalculation errors after deviating from planned course.
 - Fixed issue where a course with a very slow Virtual Partner could crash the device.
 - Fixed crash when processing Bluetooth data.
 - Added new SRAM gear presets for 13 speed gravel groupsets.
 - Fixed issue where screen would display "snow" on power up.
 - Updated Shimano STEPS terminology to "Shimano E-bike".
 - Fixed ability to use the bell while audio prompts are playing.
 - Fixed Back to Course calculation that requires a u-turn.
 - Fixed layout of graphical data fields.
 - Fix issue where both heart rate and power zones could overlap.
 - Fixed Di2 battery data field to update with proper battery level.
 - Fixed an issue where the sounds menu settings would fail to save.
 - Fixed issue where the weather widget would have valid data but fail to show it.
 - Fixed layout of map browsing page to show the map scale when a location is selected.
 - Fixed truncation of climb length on climb complete prompt.
 - Fixed some text layout issues.
 - Fixed grade value acting erratic after a suspend/resume cycle.
 - Fixed Stamina Distance to Go units.
 - Updated the icon displayed when the Edge is connected to a computer.
 - Fixed a crash that could occur on power down.
 - Fixed data screens with maps showing the wrong layers.
 - Fixed various bugs and crashes.
Changes made from version 10.18 to 10.19:
- Fixed memory leak issue that could cause a crash
Changes made from version 9.11 to 10.18:
- Added Garmin Share. Share your workouts, courses, and waypoints between compatible Garmin devices.
 - Added ecosystem-wide Garmin Coach support. Train for an event, achieve a milestone, or improve your fitness with dynamic Garmin Coach training plans for runners and cyclists.
 - Added GroupRide awards and climb competitions.
 - Added road hazards support. Get alerts for road hazards reported by fellow cyclists and contribute your own edits.
 - Added wind and stamina adjustments to Power Guide.
 - Added surface type support including on the map, in-ride unpaved road alerts, and post-ride summary.
 - Added Wi-Fi map download support.
 - Added revamped Course Creator.
 - Updated grade algorithm to be much more responsive.
 - ClimbPro
- Fixed climb clusters failing to display climb details.
 - Fixed an issue where the climb list page could highlight the incorrect current climb.
 - Fixed climbs drawing on a course when ClimbPro is disabled.
 - Retained the setting for the ClimbPro, Segment, and PowerGuide slider between page uses.
 - Added support for India basemap.
 - Added gear presets for SRAM 12 speed cassettes.
 - Added a QR code to quickly pair a Strava account with Garmin Connect.
 - Added search alias support to improve location searching.
 - Added course search to the search bar.
 - Fixed USB connection detection when coming out of suspend mode.
 - Fixed crash that could occur when saving the ride.
 - Fixed incident detection countdown timeout notification priority over any other notifications.
 - Fixed infinite elevation calibration prompt following a manual calibration.
 - Removed tone from elevation calibration prompt.
 - Fixed mute toggle interactions on the notifications widget.
 - Fixed pausing navigation.
 - Improved speed of city search.
 - Improved phonetic and hand-writing keyboard input.
 - Fixed ride button failing to show after receiving and reviewing a Connected POI.
 - Fixed friendly name for phone pairing.
 - Fixed issue where hazards in China could appear offset on the map.
 - Set minimum backlight level to retain screen visibility after backlight timeout expires.
 - Persisted backlight level setting through battery saver enable and disable.
 - Fixed battery remaining time estimate not updating when toggling Hide Map option in battery saver menu.
 - Fixed display of battery level when it dropped below 5%.
 - Fixed small roads on map being drawn too thick.
 - Fixed behavior of menus from popping back to previous page to remaining on page after data entry.
 - Fixed an issue where British coordinates could not fully be entered with the keyboard.
 - Improved layout of post-ride highlights page.
 - Fixed various crashes and freezes.
Changes made from version 9.09 to 9.11:
 - Improved performance of hazards including fixing an issue where a hazard would not prompt.
 - Fixed an issue where Power Guide target could display incorrectly after a climb.
Changes made in version 9.09:
 - Updated GNSS firmware to 11.00
 - GroupRide Improvements:
- Added descriptions and fixed values for GroupRide awards.
 - Fixed issue where GroupRide shared code is lost if consent is required.
 - Removed redundant time information in competition results.
 - Fixed GroupRide course not downloading and failing to display after a ride.
 - Fixed layout of awards list items.
 - Fixed awards taking a long time to show up in history.
 - Fixed errant climb competition winner when climb doesn't register as a competition.
 - Fixed showing start distances for competitions.
 - Fixed issue where a hazard would still be visible after a downvote on a ride.
 - Added a QR code to quick link to pair a Strava account with Garmin Connect.
 - Integrated CIQ glance theme support.
 - Fixed crash that could occur when updating Power Guide.
 - Fixed crash that could occur when navigating back to start.
 - Fixed crash that could occur when using course creator.
 - Fixed freeze that could occur during WiFi sync.
 - Fixed key press behavior when battery saver display timeout is active.
 - Fixed issue where a specific sequence could result in double swiping on timer loop pages.
 - Fixed high power consumption on the map page after loading a course.
 - Fixed battery saver estimate accuracy.
 - Fixed showing the battery was charging when the temperature range was exceeded, and battery was not in a charging state.
 - Fixed layout on the segment/climb dual approach prompt.
 - Fixed multiple issues with graphical data fields.
 - Added highlight to the selected data field.
 - Fixed font size for large data fields.
 - Added real-time settings menu for voice prompt settings.
 - Fixed display of unpaved data in course summary.
 - Fixed activity profile odometer not refreshing after a ride.
