Edge 1050 Series Version 12.18 - Live
Changes made from version 12.17 to 12.18:
  • Connect IQ bug fixes and improvements
Changes made from version 12.16 to 12.17:
  • Fixed issues with enabling/disabling bike alarm
  • Fixed custom data screens being duplicated in certain cases
Changes made from version 11.24 to 12.16:
  • Added the ability to view Garmin Coach running and strength workouts within Edge calendars (supporting wearable required)
  • Added the ability to view multiple workouts scheduled on the same day within Edge calendars
  • Fixed Altimeter calibration menu night mode issues
  • Centered GroupRide rider list around user
  • Fixed gear details showing invalid data and gear data fields not populating data correctly for eBikes
  • Added connection type information for paired sensors
  • Fixed nutrition/hydration tracking if the unit is power cycled in the middle of an activity
  • Fixed pause during the update process before the unit reboots
  • Added support for HRM 200 pairing and data
  • Added ability to update Garmin power pedal scale factors with accuracy of 4 decimal places
  • Fixed issues with third-party workouts not syncing to device
  • Fixed climb pro lines being too thick as you zoom out on the map
  • Fixed intensity minutes glance displaying incorrect values
  • Improved the algorithm used to calculate the workout execution score
  • Fixed crash when cancelling Garmin Share transfer
  • Fixed various bugs and crashes
  • Added light color mode glances for glance list
  • Fixed max speed/cadence getting cut off in certain graphical data field configurations
  • Fixed dark mode spectator messages having invisible text
  • Fixed graphical data field selection on GCM for data screen setup
  • Fixed bugs with map icons
  • Fixed electronic shifting data field sizing
  • Fixed CIQ glances from having missing backgrounds and added light mode CIQ glance backgrounds
Changes made from version 10.19 to 11.24:
  • GroupRide
    • Fixed GroupRide dynamic glance failing to update with finished ride data.
    • Fixed GroupRide awards getting reset after a power cycle.
  • Garmin Coach
    • Fixed an issue where the dynamic area would not update with the Garmin Coach workout.
    • Fixed Garmin Coach workout not showing as complete in the Garmin Coach glance.
    • Fixed issue where device wouldn't show some Garmin Coach plans in the Garmin Coach widget.
    • Fixed an issue where Garmin Coach workouts wouldn't sync.
  • Updated the jump tone to make it easier to hear.
  • Prevented device from entering MTP mode when it is turned off, but Bike Alarm is active.
  • Removed legacy FTP test.
  • Lactate Threshold estimates are applied automatically after training with heart rate.
  • Added new compass data field.
  • Added new map data field.
  • Added 10s/30s average power graphical data field
  • Added a confirmation message for successful manual altimeter calibration.
  • Fixed double radar overlay in the Connect IQ Store.
  • Fixed pairing to inReach Messenger Plus.
  • Fix map track-line issues.
  • Fixed phone connectivity issue
  • Fixed mismatching navigation arrow and distance to next arrow.
  • Muted notifications while bike alarm is set since it was triggering the alarm.
  • Fixed issue where elapsed timer would work incorrectly after suspending device during an activity.
  • Fixed an issue where record messages would fail to record periodically and leave gaps in the activity file when the phone was connected.
  • Fixed overlapping timed alerts failing to alert.
  • Fixed recovery heart rate writing to an incorrect field in an activity file so that Garmin Connect would fail to display it.
  • Fixed consistency of Climb Pro behavior on looped ride.
  • Fixed route recalculation errors after deviating from planned course.
  • Fixed issue where a course with a very slow Virtual Partner could crash the device.
  • Fixed crash when processing Bluetooth data.
  • Added new SRAM gear presets for 13 speed gravel groupsets.
  • Fixed issue where screen would display "snow" on power up.
  • Updated Shimano STEPS terminology to "Shimano E-bike".
  • Fixed ability to use the bell while audio prompts are playing.
  • Fixed Back to Course calculation that requires a u-turn.
  • Fixed layout of graphical data fields.
  • Fix issue where both heart rate and power zones could overlap.
  • Fixed Di2 battery data field to update with proper battery level.
  • Fixed an issue where the sounds menu settings would fail to save.
  • Fixed issue where the weather widget would have valid data but fail to show it.
  • Fixed layout of map browsing page to show the map scale when a location is selected.
  • Fixed truncation of climb length on climb complete prompt.
  • Fixed some text layout issues.
  • Fixed grade value acting erratic after a suspend/resume cycle.
  • Fixed Stamina Distance to Go units.
  • Updated the icon displayed when the Edge is connected to a computer.
  • Fixed a crash that could occur on power down.
  • Fixed data screens with maps showing the wrong layers.
  • Fixed various bugs and crashes.
Changes made from version 10.18 to 10.19:
  • Fixed memory leak issue that could cause a crash
Changes made from version 9.11 to 10.18:
  • Added Garmin Share. Share your workouts, courses, and waypoints between compatible Garmin devices.
  • Added ecosystem-wide Garmin Coach support. Train for an event, achieve a milestone, or improve your fitness with dynamic Garmin Coach training plans for runners and cyclists.
  • Added GroupRide awards and climb competitions.
  • Added road hazards support. Get alerts for road hazards reported by fellow cyclists and contribute your own edits.
  • Added wind and stamina adjustments to Power Guide.
  • Added surface type support including on the map, in-ride unpaved road alerts, and post-ride summary.
  • Added Wi-Fi map download support.
  • Added revamped Course Creator.
  • Updated grade algorithm to be much more responsive.
  • ClimbPro
    • Fixed climb clusters failing to display climb details.
    • Fixed an issue where the climb list page could highlight the incorrect current climb.
    • Fixed climbs drawing on a course when ClimbPro is disabled.
    • Retained the setting for the ClimbPro, Segment, and PowerGuide slider between page uses.
  • Added support for India basemap.
  • Added gear presets for SRAM 12 speed cassettes.
  • Added a QR code to quickly pair a Strava account with Garmin Connect.
  • Added search alias support to improve location searching.
  • Added course search to the search bar.
  • Fixed USB connection detection when coming out of suspend mode.
  • Fixed crash that could occur when saving the ride.
  • Fixed incident detection countdown timeout notification priority over any other notifications.
  • Fixed infinite elevation calibration prompt following a manual calibration.
  • Removed tone from elevation calibration prompt.
  • Fixed mute toggle interactions on the notifications widget.
  • Fixed pausing navigation.
  • Improved speed of city search.
  • Improved phonetic and hand-writing keyboard input.
  • Fixed ride button failing to show after receiving and reviewing a Connected POI.
  • Fixed friendly name for phone pairing.
  • Fixed issue where hazards in China could appear offset on the map.
  • Set minimum backlight level to retain screen visibility after backlight timeout expires.
  • Persisted backlight level setting through battery saver enable and disable.
  • Fixed battery remaining time estimate not updating when toggling Hide Map option in battery saver menu.
  • Fixed display of battery level when it dropped below 5%.
  • Fixed small roads on map being drawn too thick.
  • Fixed behavior of menus from popping back to previous page to remaining on page after data entry.
  • Fixed an issue where British coordinates could not fully be entered with the keyboard.
  • Improved layout of post-ride highlights page.
  • Fixed various crashes and freezes.
Changes made from version 9.09 to 9.11:
  • Improved performance of hazards including fixing an issue where a hazard would not prompt.
  • Fixed an issue where Power Guide target could display incorrectly after a climb.
Changes made in version 9.09:
  • Updated GNSS firmware to 11.00
  • GroupRide Improvements:
    • Added descriptions and fixed values for GroupRide awards.
    • Fixed issue where GroupRide shared code is lost if consent is required.
    • Removed redundant time information in competition results.
    • Fixed GroupRide course not downloading and failing to display after a ride.
    • Fixed layout of awards list items.
    • Fixed awards taking a long time to show up in history.
    • Fixed errant climb competition winner when climb doesn't register as a competition.
    • Fixed showing start distances for competitions.
  • Fixed issue where a hazard would still be visible after a downvote on a ride.
  • Added a QR code to quick link to pair a Strava account with Garmin Connect.
  • Integrated CIQ glance theme support.
  • Fixed crash that could occur when updating Power Guide.
  • Fixed crash that could occur when navigating back to start.
  • Fixed crash that could occur when using course creator.
  • Fixed freeze that could occur during WiFi sync.
  • Fixed key press behavior when battery saver display timeout is active.
  • Fixed issue where a specific sequence could result in double swiping on timer loop pages.
  • Fixed high power consumption on the map page after loading a course.
  • Fixed battery saver estimate accuracy.
  • Fixed showing the battery was charging when the temperature range was exceeded, and battery was not in a charging state.
  • Fixed layout on the segment/climb dual approach prompt.
  • Fixed multiple issues with graphical data fields.
  • Added highlight to the selected data field.
  • Fixed font size for large data fields.
  • Added real-time settings menu for voice prompt settings.
  • Fixed display of unpaved data in course summary.
  • Fixed activity profile odometer not refreshing after a ride.
