Map update failed or not
I got a map update via Garmin Express. At the end of the "installation" Garmin Express stated "update finished" but when it then looked for updates again, the same map update were listed again.
 I restarted the Edge, and checked the map manager on the device. There it mentions that an update is available for the cycling maps, but when I try to download it, nothing happens.
(It first says it needs to delete old maps, but then stays in a waiting state forever).
When I reconnect the Edge to my laptop, Garmin Express says my device is up to date. Under installed maps, Express mentions the 2025.10 maps.
So what maps are actually installed now. Why is there an update discrepancy between the device and Garmin Express.
Seems to be another Garmin fiasco to be honest.
  • The map manager on the Edge has a bug where it does not recognise the version of maps installed with Garmin Express. So it will show that there's an update available even though you have the latest version installed. Current latest version is 2025.10. Also note the maps are now called TopoActive maps, and not Cycle Maps anymore.
    Also make sure Express removed all maps of the previous version, you can see this if you go the list of available maps on the device. There should be several types of maps (TopoActive, DEM, Geocode and Climbpro), they should all have version 2025.10.
  • Thank you for your response.
    Bug #I_LOST_COUNT in the Garmin eco system
