Live as of 5/8/25
Changes made from version 26.18 to 27.13:
- Added animations to various performance graphs, gauges, and glances
 - Enabled software updates over BLE
 - Added presets for Campagnolo 13-speed groupsets
 - Added support for Varia Vue SD card reformatting
 - Added ability to save a course in the reverse direction
 - Added an 8-second timeout to the Spectator Messaging prompt
 - Added error prompt for failed software update
 - Improved altimeter accuracy with barometer outlier rejection
 - Improved user experience for pairing secure BLE sensors
 - Improved performance when loading large courses
 - Improved gear preset selection to automatically apply a valid configuration when a shifting system reports a non‑standard gear count
 - Improved handling of missing elevation data in elevation graphs
 - Improved Map Manager error handling
 - Improved Varia Vue support
 - Fixed issue where dynamic glance would not update with the current Garmin Coach workout
 - Fixed issue where dynamic glance does not update unless device is rebooted
 - Fixed issue where ClimbPro could show different lengths for the same climb
 - Fixed issue where ClimbPro datascreen was incorrectly disabled
 - Fixed issue where Garmin Coach would incorrectly show a rest day after a workout was completed
 - Fixed issue preventing Garmin Coach 'Improve Fitness' plans from syncing to the device
 - Fixed issue that could prevent activity data from saving
 - Fixed issue with incorrect time remaining in workouts when activity is paused
 - Fixed issue where the 'Stop Navigation' option could disappear too quickly
 - Fixed battery status icon inconsistency in battery low warning prompt
 - Reordered power and HR zones to match Garmin Connect (high to low)
 - Fixed GroupRide glance showing 0 riders
 - Fixed issue with sensors displaying improper name
 - Fixed duplicate data screen entry when adding new data screen
 - Fixed manual Wi‑Fi sync incorrectly reporting sync failure
 - Fixed POI not showing “add” icon in Course Creator
 - Fixed missing tone when connecting new sensor
 - Removed start timer reminder tone on non-data screens
 - Fixed issue with Accept button in connection prompts
 - Fixed issue with pairing third‑party power meters via Bluetooth
 - Fixed segment deletion in settings menu
 - Fixed color persistence on power off page options
 - General improvements to device stability and addressed various minor bugs
Changes made from version 26.17 to 26.18:
- Connect IQ bug fixes and improvements
Changes made from version 26.16 to 26.17:
- Fixed issues with enabling/disabling bike alarm
 - Fixed custom data screens being duplicated in certain cases
Changes made from version 25.25 to 26.16:
- Added the ability to view future weather conditions for scheduled Garmin Coach Workouts
 - Added camera options to Edge Remote / Di2 Remote Actions
 - Added ability to schedule a software installation for after your ride
 - Added the ability to view Garmin Coach running and strength workouts within Edge calendars (supporting wearable required)
 - Added the ability to view multiple workouts scheduled on the same day within Edge calendars
 - Fixed Altimeter calibration menu night mode issues
 - Centered GroupRide rider list around user
 - Fixed gear details showing invalid data and gear data fields not populating data correctly for eBikes
 - Added connection type information for paired sensors
 - Fixed nutrition/hydration tracking if the unit is power cycled in the middle of an activity
 - Fixed pause during the update process before the unit reboots
 - Added support for HRM 200 pairing and data
 - Added ability to update Garmin power pedal scale factors with accuracy of 4 decimal places
 - Fixed issues with third-party workouts not syncing to device
 - Fixed climb pro lines being too thick as you zoom out on the map
 - Fixed intensity minutes glance displaying incorrect values
 - Improved the algorithm used to calculate the workout execution score
 - Fixed crash when cancelling Garmin Share transfer
 - Fixed various bugs and crashes
 - Fixed issues with backlight affecting the device's temperature reading
 - Fixed Garmin Connect Mobile displaying text in a different language
 - Added map data field
 - Fixed brightness jumping to 60% after being set to 0%
 - Added graphical compass data field
 - Fixed overlapping values on some graphical data fields
Changes made from version 25.24 to 25.25:
- Fix bundle update issue
Changes made from version 24.19 to 25.24:
- Updated to MTP (Media Transfer Protocol).
- Your Edge will now use MTP (Media Transfer Protocol) to transfer files with a computer. MTP improves file system stability and enables the engineering team to continue delivering new features to your device. For Macs, this changes how you can manually transfer files to and from the device. For more information, see https://support.garmin.com/en-US/?faq=Cu7Aa5tExP4beYisOekd7A&productID=1196129&searchQuery=mtp&tab=topics
 - GroupRide
- Fixed GroupRide dynamic glance failing to update with finished ride data.
 - Fixed GroupRide awards getting reset after a power cycle.
 - Garmin Coach
- Fixed an issue where the dynamic area would not update with the Garmin Coach workout.
 - Fixed Garmin Coach workout not showing as complete in the Garmin Coach glance.
 - Fixed issue where device wouldn't show some Garmin Coach plans in the Garmin Coach widget.
 - Fixed an issue where Garmin Coach workouts wouldn't sync.
 - Removed legacy FTP test.
 - Lactate Threshold estimates are applied automatically after training with heart rate.
 - Added a confirmation message for successful manual altimeter calibration.
 - Fixed double radar overlay in the Connect IQ Store.
 - Fixed pairing to inReach Messenger Plus.
 - Fix map track-line issues.
 - Fixed phone connectivity issue.
 - Fixed mismatching navigation arrow and distance to next arrow.
 - Fixed issue where elapsed timer would work incorrectly after suspending device during an activity.
 - Fixed an issue where record messages would fail to record periodically and leave gaps in the activity file when the phone was connected.
 - Fixed overlapping timed alerts failing to alert.
 - Restored electronic shifting over-shift tone.
 - Fixed recovery heart rate writing to an incorrect field in an activity file so that Garmin Connect would fail to display it.
 - Fixed consistency of Climb Pro behavior on looped ride.
 - Fixed route recalculation errors after deviating from planned course.
 - Fixed issue where a course with a very slow Virtual Partner could crash the device.
 - Fixed crash when processing Bluetooth data.
 - Added new SRAM gear presets for 13 speed gravel groupsets.
 - Updated Shimano STEPS terminology to "Shimano E-bike".
 - Fixed adding a password protected WiFi network.
 - Fixed Back to Course calculation that requires a u-turn.
 - Fixed layout of graphical data fields.
 - Fix issue where both heart rate and power zones could overlap.
 - Fixed Di2 battery data field to update with proper battery level.
 - Fixed data precision on speed graphs.
 - Fixed ability to delete True Up activities from the device.
 - Fixed issue where the weather widget would have valid data but fail to show it.
 - Fixed layout of map browsing page to show the map scale when a location is selected.
 - Fixed truncation of climb length on climb complete prompt.
 - Fixed some text layout issues.
 - Fixed grade value acting erratic after a suspend/resume cycle.
 - Fixed Stamina Distance to Go units.
 - Updated the icon displayed when the Edge is connected to a computer.
 - Fixed a crash that could occur on power down.
 - Fixed clipping of icons in the Distance to Next data field.
 - Fixed data screens with maps showing the wrong layers.
 - Fixed various bugs and crashes.
Changes made from version 24.18 to 24.19:
- Fixed memory leak issue that could cause a crash
Changes made from version 21.18 to 24.18:
- Added Garmin Share. Share your workouts, courses, and waypoints between compatible Garmin devices.
 - Added ecosystem-wide Garmin Coach support. Train for an event, achieve a milestone, or improve your fitness with dynamic Garmin Coach training plans for runners and cyclists.
 - Added GroupRide awards and climb competitions.
 - Added road hazards support. Get alerts for road hazards reported by fellow cyclists and contribute your own edits.
 - Added wind and stamina adjustments to Power Guide.
 - Added surface type support including on the map, in-ride unpaved road alerts, and post-ride summary.
 - Added Wi-Fi map download support.
 - Added revamped Course Creator.
 - Updated grade algorithm to be much more responsive.
 - ClimbPro
- Fixed climb clusters failing to display climb details.
 - Fixed an issue where the climb list page could highlight the incorrect current climb.
 - Fixed climbs drawing on a course when ClimbPro is disabled.
 - Retained the setting for the ClimbPro, Segment, and PowerGuide slider between page uses.
 - Added support for India basemap.
 - Added gear presets for SRAM 12 speed cassettes.
 - Added a QR code to quickly pair a Strava account with Garmin Connect.
 - Added search alias support to improve location searching.
 - Added course search to the search bar.
 - Fixed USB connection detection when coming out of suspend mode.
 - Fixed crash that could occur when saving the ride.
 - Fixed incident detection countdown timeout notification priority over any other notifications.
 - Fixed infinite elevation calibration prompt following a manual calibration.
 - Removed tone from elevation calibration prompt.
 - Fixed mute toggle interactions on the notifications widget.
 - Fixed pausing navigation.
 - Improved speed of city search.
 - Improved phonetic and hand-writing keyboard input.
 - Fixed ride button failing to show after receiving and reviewing a Connected POI.
 - Fixed friendly name for phone pairing.
 - Fixed issue where hazards in China could appear offset on the map.
 - Set minimum backlight level to retain screen visibility after backlight timeout expires.
 - Persisted backlight level setting through battery saver enable and disable.
 - Fixed battery remaining time estimate not updating when toggling Hide Map option in battery saver menu.
 - Fixed display of battery level when it dropped below 5%.
 - Fixed small roads on map being drawn too thick.
 - Fixed behavior of menus from popping back to previous page to remaining on page after data entry.
 - Fixed an issue where British coordinates could not fully be entered with the keyboard.
 - Improved layout of post-ride highlights page.
 - Fixed various crashes and freezes.
Changes made from version 21.17 to 21.18:
- Fixed potential crash and lap data loss when turning the device off mid-ride
Changes made from version 21.16 to 21.17:
- Fixed connection issues with BLE sensors that do not support secure connections
Changes made from version 20.19 to 21.16:
- Added support for button control and trim adjustments for SRAM AXS shifting systems
 - Added the ability to send and share locations from Apple Maps
 - Fixed glance refresh issues on the main page
 - Added lap ascent and descent data fields
 - Fixed solar graph display on post-ride highlights page
 - Fixed courses with special characters not loading properly
 - Fixed connectivity of Polar Verity Sense
 - Fixed an issue with GroupRide course downloads
 - Fixed issue where lock on road setting was not being honored
 - Fixed issue where true-up activities could not be deleted
 - Fixed frequent disconnect issues with 2M PHY connections
 - Fixed an issue causing excessive battery drain during suspend
 - Fixed an issue with real-time settings data screen layout editing
 - Fixed partial display update issues with suspend mode
 - Fixed issue where BLE sensors would not connect
 - Fixed potential issue where segments on the filesystem were not drawn on the map
 - Fixed audio prompts for speed
 - Fixed issue with elevation calibration prompt appearing repeatedly
 - Fixed off-segment tone issues
 - Fixed VO2 display on four-week history graph
 - Improved default connection interval for BLE peripherals connected via Connect IQ apps
 - Fixed issue causing translations to be removed
 - Fixed crash when importing large GPX files
 - Fixed road lines being drawn with the wrong style
 - Fixed issue where auto brightness would stop working
 - Fixed crash when drawing the alpha mask for CiQ icons
 - Fixed hourly wind speed display
 - Fixed workout comparison graph in ride history
 - Fixed gear battery data field for certain ANT sensors
 - Fixed CiQ data fields with developer data not appearing correctly
 - Fixed issue displaying courses on certain maps
 - Fixed positioning issues near Chinese borders
 - Fixed searching issues with Japanese keyboard
