Edge 1040 Series Version 21.17 Now Available
Firmware version 21.17 for the Edge 1040 Series is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
Live at 100% as of 6/05/2024
Changes made from version 21.16 to 21.17:
  • Fixed connection issues with BLE sensors that do not support secure connections
Changes made from version 20.19 to 21.16:
  • Added support for button control and trim adjustments for SRAM AXS shifting systems
  • Added the ability to send and share locations from Apple Maps
  • Fixed glance refresh issues on the main page
  • Added lap ascent and descent data fields
  • Fixed solar graph display on post-ride highlights page
  • Fixed courses with special characters not loading properly
  • Fixed connectivity of Polar Verity Sense
  • Fixed an issue with GroupRide course downloads
  • Fixed issue where lock on road setting was not being honored
  • Fixed issue where true-up activities could not be deleted
  • Fixed frequent disconnect issues with 2M PHY connections
  • Fixed an issue causing excessive battery drain during suspend
  • Fixed an issue with real-time settings data screen layout editing
  • Fixed partial display update issues with suspend mode
  • Fixed issue where BLE sensors would not connect
  • Fixed potential issue where segments on the filesystem were not drawn on the map
  • Fixed audio prompts for speed
  • Fixed issue with elevation calibration prompt appearing repeatedly
  • Fixed off-segment tone issues
  • Fixed VO2 display on four-week history graph
  • Improved default connection interval for BLE peripherals connected via Connect IQ apps
  • Fixed issue causing translations to be removed
  • Fixed crash when importing large GPX files
  • Fixed road lines being drawn with the wrong style
  • Fixed issue where auto brightness would stop working
  • Fixed crash when drawing the alpha mask for CiQ icons
  • Fixed hourly wind speed display
  • Fixed workout comparison graph in ride history
  • Fixed gear battery data field for certain ANT sensors
  • Fixed CiQ data fields with developer data not appearing correctly
  • Fixed issue displaying courses on certain maps
  • Fixed positioning issues near Chinese borders
  • Fixed searching issues with Japanese keyboard
