Tons of bugs
I'm very disappointed, 1040 is the premium edge device with premium price too.
But lot of bugs.
Yesterday, it was my second Audax (300 km), And I experienced same bugs like my previous one. Firmware 16.13
- Charging : when pug in charger, Edge switch to sleep mode and stop to charge
- Accuracy : After few hours, suddenly I'm out of the gpx track. Disabling GPS and re-enabling and it was ok for few minutes. When re-enabling with GPS-Only it was ok, but precision was not very good
- Barometer : In raining condition, clim percentage is bad. Seems- to be a design problem => https://forums.garmin.com/sports-fitness/cycling/f/edge-1040-series/328452/elevation-and-gps-precision-in-wet-condition---issue So no solution for customers.
- Home screen : every time i start the 1040, I'm at the end (last item) of the home screen, very annoying to switch between profiles.
- direction: When you just change direction, next direction stay with the last one (and 0 merter) for at least 20 seconds ... And it was the same with "popup" when you are using climpro. So if you have to direction change close together, the second will be never displayed.
- climpro latency ...
Looking to move to karoo or whaoo roam v2 ...
  • Again, if the accuracy is not working then something is off with your personal device or settings. Mine is working perfectly fine, reviews have shown that it is spot on.
    Even in some canyons where half of the sky is covered with mountains the gps track stays on the road.
    Also, when the screen is not showing the device is charging just unplug and plug in again.
    Try troubleshooting.
