Can anyone report if Garmin have fixed the issue that the 1030+ has with ridiculously long responses to changes in gradient?
Thank you for sharing your concerns about the undesirable lag in road grade. We want to share that we have a plan for an improved solution with consideration of both accuracy and responsiveness. Our engineers…
@Garmin-Mathew.
If you really believe that 10-15 seconds delay is considered “normal” - as the official statement from Garmin is trying to force-feed customers, then what does that say about my Edge 1000…
I currently have a wahoo element (full size) a karoo2 and now a 1040 solar. as of the 12.14 release the 1040 solar still has a ridiculous lag as compared to the other two. I really don't care too much…
Like many peoples, i found this lag is not acceptable for the latest and expensive garmin 1040. My old edge 1000 is better on this point.
I am quite disappointed by this decline of quality and the lack of reaction of garmin. I cannot recommand garmin product at this time
Garmin: please focus on this!
So this debate is still ongoing. This is definitely a Garmin “Design Feature” and the debate has been ongoing for years with previous Edge models.
https://forums.garmin.com/sports-fitness/cycling/f/edge-1030/212208/grade-digits
This above post shows the removing of the decimal point was a conscious design decision. I think probably at this time they also flattened out the gradient as reported on page 6 by the Garmin consultant:
The current algorithm appears to use a 15 second rolling average to smooth the value, which leads to the lag that has been reported.
I do not think Garmin will change this as they have taken no notice for all these years of complaining is this and other posts.
No, that is not correct, it's NOT using an average, certainly not explaining up to 15 seconds. I have tested a lot this week and I'm sure about that. And in that you quoted it's "appears to use a 15 second rolling average to smooth". I think it's just a guess.
Garmin's official explanation is "This lag is a result of the amount of data inputs being processed"
https://support.garmin.com/sv-SE/?faq=kZjqTdE5ks374UVhZNHmAA
not some average.
I have a short tour I have tested some times now, one short dale(english?), down 3m and up again in 150m total, and one up and down where the ascent is appr. 100m long.
2 times when I have tested this the altitude is lagging appr. 15 secs (and the gradient some second(s) more) - on the way out. When going back again there is NO lag! The "funny" thing is that in the short "dale" the last time I did the test the saved data is almost 1 second ahead of the real altitude on the way back. I noticed that also when riding, it was quicker than my Edge 800 which I had to compare with, both altitude and gradient. I repeat no lag when going back on the same way. That is no lag for altitude, and some second(s) for the gradient, as it must be.
BTW, today in a different route I had at least 20 seconds lag of altitude (and gradient some more) in both directions.
Perhaps it's some heavy calculating comparing with GPS and/or saved data somewhere. One thing I want to know, was the gradient lag introduced at the same time as Climb PRO or something comparable with that?
244,
If you look back through the current 27 pages of this post, you will see that I have performed numerous tests.
The 1000 was pretty Ok in the gradient respect. No sensor can be 100% accurate, but it gave you a reasonable idea of where you are on a climb. The processor in the 1040 is supposed to be an upgrade (one would hope so as it’s 8 years later).
I worked in computers and your comment “heavy calculating” shows that you did not. A 20 year old chip could process the data required to calculate the Gradient in milliseconds. One would hope the 1040 chip could do this in nanoseconds.
There is very little data in the .FIT as regards position, entries are in the seconds, there are not 1000’s of entries for a 50M section of climb.
This is a design feature as per the Garmin Consultant, whether it’s 15sec, a few less or a few more is irrelevant, this is the way they are displaying the Gradient and almost no one agrees with them.
Sorry, but the use of the term “a design feature” is an OXYMORON, regarding this NEW, super duper, upgraded, nano second-reacting chip.
That is - “design featured” by Garmin engineers and marketers, to react in 15 seconds, to give an approximate gradient reading that is more or less as reliable, as the 8-10 yr old Edge 1000, which reacted in 2-3 seconds!
Sheesh…
