Garmin edge 1030 paired with SRAM GX AXS sensor
Hi
when I pair my AXS gear /sensor with my Garmin edge 1030. And I try to edit sensor details. I can only select 2 gear on front and 11 gear on back, I can’t figure out how to input a 1-12 drivetrain.
I am running latest firmware 11.1 for edge and just updated firmware for AXS
Any help or experience out there would be much appreciated
Regards
Lass
  • After pairing with the shifting sensor, shift up and down the cassette, and after doing that you should then be able to configure the gearing correctly on the 1030. That's what I did to enable me to setup Eagle AXS 1 x 12 cassette cogs and chainring on my wife's Edge 1000. Straight after initially pairing, I had the same problem as you're seeing until I shifted across the cassette.
  • Thanks, that actually helped. After doing so it self configured
