Firmware version 10.00 for the Edge 1030 and Edge 1030 Bontrager is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile.
Phased Rollout is currently at 100%
Changes made from version 9.50 to 10.00:
- Segments
-Fixed issue with detecting segments that were going in the opposite direction of travel
-Improved segment and ClimbPro UI cooperation
-Fixed issues when approaching a segment embedded in a course and other minor segment UI issues
-Fixed issue where segment virtual partners would claim to be finished almost immediately after starting the segment - ClimbPro
-Improved estimated time to end of a ClimbPro climb
-Fixed ClimbPro page graph drawing
-Fixed issue where disabling "Pop-up on Climb Approach" would disable ClimbPro completely - Improved iPhone pairing
- Improved sensor connectivity
- Improved automatic FTP detection
- Added Go Back, Pause, and Go Forward workout step controls to the workout tray
- Added option to delete a data field in quick edit mode. Access by pressing and holding a data field on a timer page.
- Improved grit and flow consistency between Garmin products
- Improved bike light connection stability
- Fixed bike alarm not turning off after correct password was entered
- Fixed radar vehicle drawing temporarily not updating
- Added a shortcut to the display menu by pressing and holding the Auto Brightness button on the status widget
- Added a toggle for MTB map theme
- Improved MTB trail search UI
- Fixed issue where history line wasn't updated while panning in the map
- Fixed issue with the number of power zones displayed post ride
- Fixed dual sided power meter calibration factor reporting only one side
- Fixed Firstbeat metrics for multiple rides during the same power cycle
- Fixed Training Effect UI layout
- Removed unnecessary beeps for notifications that don't need them
- Fixed timezone map downloads from WiFi
- Fixed issue with power targets in TCX workouts
- Made various device stability improvements
