Garmin Edge 1030 Boot Up Problem.
If your unit is stuck trying to boot, then the following may work...
to force to mass storage mode
Mount the unit to the computer, you may need to use a force mount (see below). Remove any files that maybe in the Garmin\NewFiles folder.
Force to Mass Storage -
Turn unit off. Hold the lap/reset button while plugging the unit into the USB. Continue holding the lap/reset for 30 seconds and the unit should go to mass storage.
Thank-you for the tip, that worked for me. There were 300 .fit files in my NewFiles folder - maybe from the Strava Routes app. Cleared them out, and I'm back in business.
See this thread/ Seems to have helped some.
https://forums.garmin.com/sports-fitness/cycling/f/edge-530/165549/edge-530-stuck-on-startup-screen
Sounds like you've tried everything. Probably time to contact Garmin Support.
