Never had this problem with my "old EDGE1000".
No I am using a EGDE1030, and i have power&cadans drops while i am riding.
the drops are mostly 10 sec ore less.
Have anyone a solution for this?
Using the latest Updates from 4iiii and garmin.
Can you share the .fit file from this ride?
I have the 4iii and no problems whatsoever. Do you connect using ANT+ or BT?
I am using ANT, i do not know how to use Blue Tooth.
i have read to switch to BT, but i must learn how to, i do not see this option.
i will do that.
I have a 4iiii Precision Pro dual sided and I get drops on the 1030. I have a 705 mounted and it sometimes drops, but quite often I will see power showing on it when the 1030 shows nothing. I always thought I just have to live with it. Is there a solution?
I'm also getting 10 second power and cadence drops with my Podiiiium and an Edge 520 Plus. I've also tried recording a ride simultaneously with a Fēnix 5S Plus, and got exactly the same drops there.
Hi, I've edge 705 and willing to buy a 4iiii but my device is not listed in compatibility list.. do you confirm it works on 705?
Yes, my 4iiii connects just fine with the 705. ANT+ Power protocol has remained the same for many years. The 705 just does not have many of the interesting data fields the newer devices have, like %FTP, or L/R balance, but the data is recorded.
thank you very much for confirmation!!
i'm not interested in L/R balance as Precision PM is just left-sided..
mine 10yrs old 705 even after spectacular drops at 60+ kmh won't die so it's nice to see that i can continue using it! :D
I'm experiencing drop outs as well.
