SOLVED!! As indicated by _Richi, the course sort order can be adjusted with Firmware 8.0 or later:
This can also be accessed from Training:
This has been solved.
Martin868, thank you! That is actually quite clever! I am working on completing a collection of rides, and naming them with a common acronym will make them easy to find. Also, the course names can be changed after a ride to indicate that a specific course has completed.
Sometimes, a simple solution is best!
Your solution, coupled with the sorting options introduced after Firmware 8.0 which includes the "Distance to Start" sort order will make finding the next course much easier!
