Edge 1000 switches off when SD card inserted
Hello,
I have a Garmin Edge 1000, and without SD card it works fine. But if I try to turn it on with SD card inserted it will switch off each time shortly after loading. It will also switch off shortly after SD card is inserted once it's on and running. Once connected to PC, SD card drive is shown, but empty as if no card inserted.
Has anyone else had similar issues? Is there anything I could try in order to sort this out or is it just a faulty card slot?
