• [14.66] Battery drain 25% higher than in 14.36
    As tittle says, on my Epix (Gen 2) with same settings and same usage the Watch running 14.66 consumes 25% more battery per day compared to 14.36.
    With 14.66 it consumes 6% a day which live up to the 16 days promised battery. BUT with 14.36 it only consumed…
  • Sudden battery drain Vivoactive 4
    I had Vivoactive 4 for 2 yearsand it worked fine until recently when it started draining battery more quickly than before.
    It uses about 1% per hour on stock watchface and without pulseOx (BT disconnected), and it used about 0,5% until recently in same…
  • Sudden return battery drain (maps switched off, fw5.0)
    This night woke up at 4am because my forerunner 945 had only 10% battery left and signaled. Few seconds later it went out completely. This morning on the charger checked.....no update (still firmware 5.0) and maps still unchecked (seemed the reason for…
  • RE: Battery life for epix 2.
    You probably have pulse ox on. It drains battery. Better to turn it off. It's not usefull for normal situations anyway.
  • Battery draining 20-25% per day
    I bought VA4 about a week ago, fully charged it to 100%. Pulse ox off, notifications off, gestures low sensitivity, timeout fast, brightness 10%. Used Garmin watch face.
    Had one 30 minutes cardio session, otherwise on smart watch mode the whole duration…
  • RE: Battery drain on Venu SQ Music
    I’m sorry to hear of the battery drain issues that you’re experiencing.  Let’s start by power cycling (turning off and then back on) your watch.  If the battery drain persists and if you have any Connect IQ (CIQ) Content, especially watch…
  • Marq Aviator Battery Drain 4.10 FW
    Changed the firmware yesterday to 4.10 and the battery is draining in less than 24 hours. I had added Amazon music and I thought this was draining the battery or the issue, then I could not uninstall it.  I have performed a hard reset and then was able…
  • RE: Battery Drain Instinct 2 (15% per day)
    - i did install some watch faces on the first day of arrival.
    Uninstall them
    i didn't use gps tracking, i believe the activities i tracked are based on the phone's gps.
    That's not possible. If you see a track map in…
  • The battery drains in a day with 9.19b
    Ever since I installed version 9.19b, my Vivoactive 5 battery drains in a day, whereas before it lasted 12 days. Please, solve this issue. Thank you
  • RE: Massive battery drain from chest strap
    Watch using ANT+ doesn`t establish connection (in simple terms)  with accesories, it listens signals from devices. "adding" device to watch is just configuring watch to do not ignore broadcasted data from certain ID.
    So battery "drains" are caused…
