• WatchFace draining battery?
    https://apps.garmin.com/nb-NO/apps/9fd04d09-8c80-4c81-9257-17cfa0f0081b
    Will this Watchface drain a lot of battery? It's Crystal and its to top one in the store.
  • Battery drains faster than before the 21.00 update
    I’ve noticed that the battery is draining faster when no activities have been used. Everything I have on my watch now has always been on my watch. After the update my battery will drain from 100% before bed to 60% the next day and it usually takes 3 days…
  • RE: Vivoactive 3 battery drained
    Hey I got the same problem after latest software update. For me it seems like it has something to do with GPS probably staying active after a activity. I went for a walk and then it drains after activity. I realised a temporary fix. Doing a "hard-reset…
  • Battery drain still not fixed in 20.31
    Is there any plan to fix battery drain at all?
    And please don't paste links to battery optimization page, because all my settings are the same as were before version 20.x
    Restart after activity doesn't stop battery drain and share is disabled.…
  • Battery drain on Vivoactive 4
    Hello,
    Without changing anything in my watch usage, the battery that was lasting 2 to 3 days drops to a day, and to half a day, to a couple of hours.
    I delete absolutly everything on it, factory reset : same battery drain.
    As the watch is 2 years and…
  • VA3 battery drain after vibrate alarm
    Hello all,
    I've seen numerous posts regarding battery life, but none covering the scenario I'm seeing with my vivoactive3, (if I've missed it, apologies).
    I've had my VA3 for a fortnight and seen some very strange battery drain rates:
    First…
  • RE: Fenix 5 with 14.1 update high battery drain
    Fenix 5s with 14.10 and sensor 6.90
    Still having same issue :
    With Optical Heart rate : 3.2% battery drain per hour
    Without Optical Heart rate : 0.4% battery drain per hour
    Cold sweat
  • Garmin 970 Battery Drain - v6.18
    After update to 6.18 the battery on my 970 drains from 100% to 70-80% overnight with all low consumption settings - AOD off, night face and standard watch face during day, Pulse Ox off etc. Anyone else experiencing same issue? Only used to drain a couple…
  • RE: Battery drain issues with 955 Solar
    I bought mine Feb 10, I left the battery drain until it had around 5% left (out of the box battery)... It reached 100% in a couple of hours.
    Afterwards, I wore it for 3 hours whilst working in my desk and battery drained to 95%.
    After browsing through…
