• VIvoactive 3 - Data lost and battery drain
    I bought a VA3 (firmware 5.50) 2 week ago and I experienced the following two bugs:
    1. after updating the firmware or after a complete battery charge, the tracker suffer a huge battery drain: about 3-4% of charge per hour. The solution is to restart the…
  • RE: 14.2 Battery Drain and other weird behavior
    The battery drain problem has been arround since 13.40 version. I made a ticket with garmin support back then and reverted back to the 13.3 version since then. A few days ago I get this email:
    "We have identified a possible issue with software version…
  • RE: Battery Drain Vivoactive 3 Music
    Hello,
    My vivoactive 3 is also draining the battery. Software version 7.80
  • Vivoactive 5 battery drain - SW 13.19
    A few weeks ago my Vivoactive 5 started to drain the battery in under 3 days, even with no activity. I've had it around 18 months and prior to this a full charge would easily last 10 days, activity dependent. It is currently showing software version 13…
  • My battery drains after 55%
    I just got this watch a month ago and I noticed my battery starts to drains quicky after 50%. I didn't even use the watch overnight it went from 54% to 19% when I'm sleeping. Can someone please help me? This is ridiculous. I did a soft reset too and that…
  • RE: Battery drain issue continues after months
    My VA3 has battery drain since the last update to 7.50 (about a week ago) and now it won't barely hold a charge for 2 days. Tried to factory reset multiple time and even changing the phone do no good ConfusedConfused
  • RE: Significant battery drain after 2.50 update
    I experienced some decent battery drain as well; 78% at time of install and then the next morning (9hrs later) I was at 35%.
    Since recharging and powering the watch off and back on, it seems to be doing fine.
  • RE: FR955 with FW14.15 Battery Drains a lots
    In my case, I have touchscreen disabled 99% of the time, so the big battery drain is without it.
  • Battery drain after dimissing activity
    I've seen the thread about it keeping GPS on after GPS activity but I think I'm similar but slightly different.
    When zwifting I start the watch recording an "indoor cycling" activity, mostly to force it to use my chest strap HR rather than wrist…
