• Battery drain after V4 update
    I updated yesterday, and since then the watch has drained significantly faster than before.
    Yesterday I drained from 100% to 35% just having it as a watch during the day and recording 1 activity (without phone GPS) for an hour.
    Today over the same time…
  • Battery Drain on 9.19 Beta
    There is problem with beta 9.19 there is battery problem Can we go back live version on Vivoactive 5?
  • Battery Drain Since Latest Update
    I plugged my Venu in last night and charged it, then wore to bed.  When I looked at the dial this morning at 9, the battery had died.  Usually lasts 3-4 days with my normal activity.  Seems like some update ran overnight that is affecting battery life?
  • Vivoactive 4S battery drain/problem
    Hi, I've problem some times with battery life. Vivoactive 4S was bought 3y ago. It works fine around year and half, but than begin problems - lifetime of one charging cycle was only for one day / without using watch for any GPS activity or BT connection…
  • Battery draining in a day
    About 2 weeks ago, my watch battery started losing power rapidly and has needed charging daily. It used to go several days without a charge. Now, it loses 30% whilst I'm asleep! My boyfriend's watch has the same issue. The software is up to date. Does…
  • Battery drains with watch off
    After I charged my watch to 100%, I turned it off and after 5 days I turned it back on and the battery is completely dead. It's only a year old, is something still running even when it's off? My cordless power tools batteries when not in use last for…
  • RE: Venu Sq / Sq music battery drain (since 3.3 ?)
    I am also having a larger than normal battery drain.  I am going to re-set it back today and I’ll post the instructions assuming I figure it out correctly.
  • RE: Vovoactive 4 battery drain after update to 4.70
    Step 1-3 definitely did the job for me a week ago.
    Plus:
    Don't install third party apps/data fields from Garmin IQ Shop.
    These can trigger high battery drain.
  • Major Battery Drain on 17.20
    Is anyone else having an issue where the watch is depleting the battery in under 4 days? I used to get ~18 days before having to recharge my Fenix 7 Pro.
  • Battery drain high after update to 21.19 on Forerunner 265
    Battery drain seems very high! After update, charged watch to 100%, drained to 52% overnight.
