• Battery drain of new SQ2 music edition device
    Battery drain of my Venu SQ2 in 4 days.
    Bought the watch on 17th Feb 2024, battery does not last more than 4 days. GPS mode only when walking. Not used Spo2 as well.  Any tips to improve?
    Have reached out to service centre, they ask for the device to be…
  • RE: Battery drain in 12.14
    0.1% is not drain, it's normal value as it should be from the beginning. I'm stuck on 0,25%/h with same settings as yours.
    F8 51 Solar  12.14b
  • Rally pedal drains battery (right side)
    can anyone help me with my rally pedal issue. I've replaced new battery on both sides of my rally pedal. but my right side pedals battery drains and die in 5 days. I replace a new battery on the right side and still dies in 5 days. the left side is good…
  • Still Batterie drain on 18.16
    Normally I had about 7-8% of battery use today.
    now I have about 14%.
    restarting, reinstalling etc. Nothing works.
    sorry for the toot words, but I’m wondering when Garmin finally will fix this.
    I’ve own my watch for Little mit more than 2 years…
  • Battery drain Fenix 7x pro
    I noticed much higher battery consumption in the new version of the software. Battery life is about 50% shorter. Without using GPS, the battery drops by about 10% during the day. one hour of running with GPS, battery drop approx. 4%. The settings are…
  • RE: Vivoactive 4 Serious Battery Drain after update 6.10
    After turned off the watch, wait for 5 min and turn it on backlight issue has been fixed.
    now let’s see if battery drain issue has been fixed .
  • Fast battery drain on 12.23
    Watch face without showing second, and HR; Garmin OEM and custom watchfaces behave the same. After installing 12.23 version I am facing drastic drain comparing with 12.20.
  • Battery drain 25% per night
    Occurred twice this week. On Sunday 93% -> 70% per night and yesterday 50% -> 25% per night.
    Normally watch drains around 5-6% for the whole day.
    How to debug it?
  • RE: FR235 Battery Drain Then Sudden Death
    Flip it over. Are the green lights on all the time? If so, that's likely why your battery is draining so fast. I believe this is a sign of a faulty watch which usually ends up in a replacement from Garmin. I'd contact them if this is the case. …
  • 20.14 - Huge battery drain when using GPS all systems
    I am experiencing huge battery drain in beta FW 20.14 - about 3-4% during 1/2 outdoor activity. Already did factory reset, recover from backup. It did not help.
