I’m on SW 7.8 and have noticed bad battery life over the past few weeks.
I’m suddenly down to ~70% drop in less than 2 days and sometimes the battery will drop 30% in just a couple of hours and then level off.
Charging also seems way too…
Finally after a year of ownership a method to stop the battery drain! I have been doing this for the last couple of days and it appears to work.
Since last update battery goes from 100% to 75% in single day. When I bought garmin venu 2s I was promised 11 days of battery life on smartwatch usage and now it does not last few days, this is unacceptable. Don't release software if not tasted properly…
Hi,
After charging to 100% - battery was drained to 94% in one hour, no activity, no touch, no wifi, only BT connect with phone.
my epix pro 51mm after the first charging kept me around 19 days. with second charging after 6 days has lost 70% with the same use and without changing any settings. Is it normal?
UPDATE: the 3rd time I charged through a usb-c in a laptop. Until now it…
Hi! I am facing the this issue since a couple of weeks.. I have purchased my Instinct in August of 2019.. worked flawlessly until a couple of weeks or so.. battery has been draining within a day! 23.5 hours to be exact (I turned on stopwatch and checked…
Full battery in normal is about 28 days
After "upgrade" is now only 20 hours
Since past few days I have noticed that my watch is draining battery within 12 hours of usage. I have to charge it twice a day now. This has happened just a few days ago before which it was working fine and I was able to keep the charge for about 5-6…
Seems something is wrong with battery - yesterday evening after training i had approx 50% of battery and i woke up in the morning and noticed it's discharged (screen attached).
Other thing i am obserwing - i charged the battery to 100% and i went…
I compared time on battery from April with time on latest beta (same watch settings):
April: 12 days 4h with 4h30 GNSS activity and 2h45 Indoor Climbing
Now: 11 days with 4h26 GNSS activity.
