Hello MARQ customers,
We have new software available for your upcoming adventures!
*Our 9.92 Beta contained ANT/BLE software version 6.03, however, we believe this peripheral software update has includes a bug that could lead to phone connection problems, or disconnects from sensors/headphones. The 9.95 update folders contain the file needed to backdate the ANT/BLE software from 6.03 to 5.04, which we recommend that you install if you have a MARQ device. The instructions for installation provided on the above links remain the same, no additional steps are needed for installing the backdate file.
The beta below is not compatible with MARQ Aviator.
MARQ: https://www8.garmin.com/support/download_details.jsp?id=15220
Instructions for installation are available below the change log on the page linked above.
9.95 Change Log Notes:
- Fixed an issue with repeat and skip functions when using Spotify.
- Fixed an issue where playlists with Cyrillic characters would not display correctly on device.
- Fixed an issue where sensor icons were being displayed in the status bar even when disabled using a power mode.
- Fixed an intermittent issue where 'Around Me' search would not complete.
- Improved the visibility for Dogtrack by allowing one to pair to it through the sensors menu and automatically removing the widget once the sensor is removed.
- Made a couple of improvements for golf.
- Updated the UI for Body Battery and Training Status widgets.
Current beta peripheral software version numbers below. New versions are indicated in red.
GPS: 4.40
Sensor Hub: 7.11
ANT/BLE/BT: 5.04 *See note above
Wi-Fi: 2.60
Please note, the beta updates released on these forums are not suitable for APAC region devices.
Please send all bug reports to [email protected], and indicate which model of the MARQ Collection you have in the subject line.
