MARQ - 7.77 Beta Release
Hello MARQ customers,
The newest MARQ beta software is now available for your upcoming adventures! The beta below is not compatible with MARQ Aviator.
MARQ: https://www8.garmin.com/support/download_details.jsp?id=15220
Instructions for installation are available below the change log on the page linked above.
GPS changes from 2.80 to 4.01: Improve total distance computation in ultratrac mode for cycling activities.
7.77 Change Log Notes:
  • Added support for connecting to a shifting sensor (Sram Etap or Di2 bike) that supports up to 4 front and 12 rear gears.
  • Add support for using Widget Glance fonts in Connect IQ.
  • Added support for Grit and Flow data fields for MTB.
  • Added support for a ‘Silent’ option to the Smart notifications Sounds alert settings. (Menu > Phone > Smart Notifications > During Activity/Not During Activity > Sounds)
  • Fixed an issue where the device would crash when starting a POI search right after canceling an “Around Me” search.
  • Fixed an issue where features that auto-enable during the sleep window were not working as expected. (For Ex: Battery Saver.)
  • Fixed an issue where the device would erroneously display an assistance banner after disconnecting from USB.
  • Fixed an issue with Brazil Daylight savings time.
  • Fixed a couple of issues that should improve device stability.
  • Fixed a couple of altimeter calibration issues. This should address speed spikes in activities with 3d speed enabled. (For example: Ski.)
  • Fix always showing the Updating spinner when changing an alarm.
  • Fix a potential crash when using the Breathwork app.
  • Fixed an issue where the watch may freeze during a Ski activity.
  • Improved the user experience when call related notifications are received.
  • Improved the layout on the Ski Run Data Page.
  • Improve responsiveness when adding or removing favorites.
  • Improve display of Grit and Flow data-fields for the MTB app.
  • Improved error handling when using the Garmin Pay Wallet.
  • Improved error handling for downloading Heart Rate from a strap, by notifying the user if one attempts to download Heart Rate data over Bluetooth vs ANT.
  • Made several improvements to Clocks.
  • Made several improvements to Breathwork.
  • Made some improvements to the DogTracker widget.
  • Made several other bug fixes and code improvements.
Current beta peripheral software version numbers below. New versions are indicated in red.
GPS: 4.01
Wi-Fi: 2.60
Sensor Hub: 5.05
ANT/BLE/BT: 4.30
Please note, the beta updates released on these forums are not suitable for APAC region devices.
Please send all bug reports to [email protected], and indicate which model of the MARQ Collection you have in the subject line.
