Watch does not turn on anymore, only works when connected to power.
My watch stopped working and does not turn on anymore, it only works when connected to the charger or computer, and turns off immediately after being disconnected, I recorded a video of the issue:  https://youtu.be/BozEaofJU4Y
  • I am sorry to hear you are having trouble with the watch shutting off/not powering. For this, I would confirm the watch is charging to 100% before disconnecting. If it is not fully charging, I would recommend cleaning the contacts on the back of the watch and cable. We recommend using rubbing alcohol for this.
    You can also use another cable, as well as try charging with a computer and wall outlet.
    If this is continuing to shuts off, I would recommend completing a factory reset, while connected to power. For this, we recommend using these steps:
    If this is continuing to shut down, the watch will likely need to be replaced. For this, we recommend contacting our local Garmin Product Support.
