Is there a way to lock current widget screen instead of always returning to the set face after so many seconds? I know it is possible on other Garmin devices but it does not appear to be available for the instinct solar.
EDITED:
Yes. Use your "lock keys" feature.
1) Go into your widgets and put your watch on the widget you want to keep on your display at all times.
2) Long hold your CTRL button and select the lock icon.
Your Instinct Solar is now locked on the widget but will go back to the main time display in approx. 2 minutes. The lock feature only pertains to the keys themselves to avoid accidentally pressing them. The same behavior experienced when not using the lock key feature, is what you will experience on your watch when using the locked keys feature. IE: if actively recording an activity, it will remain on the activity like normal but the keys will be locked.
Long hold any button to unlock and then use your Set button to back out back to your main time display.
Excellent, thank you.
