So when I long press the set button, I am only seeing the Quickt timers. I don't see stop watch, alarm and other time functions... Any ideas? Thanks in advance.
Long press on the set button is a hot-key. This is configurable and will show whatever is set under Settings - System - Hot Keys - [Hold Back].
Long press on the Ctrl button will bring up the controls menu…
When you go to the Settings > System > Hot Keys menu, ensure the "Hold Back" option shows as "Set". Otherwise, you will only see one field. IE: Quick Timer or Alarm etc and that is…
Long press on the Ctrl button will bring up the controls menu which should have the functions you have mentioned (if they are visible under the Settings - Controls menu)
When you go to the Settings > System > Hot Keys menu, ensure the "Hold Back" option shows as "Set". Otherwise, you will only see one field. IE: Quick Timer or Alarm etc and that is the only field the long hold of your set key will show you.
Hi thank you for that! Unfortunately, I couldn't figure it out before your reply so I ended up restting the watch :(.. Luckily I didn't have too many custom settings on it...
