I3 Solar 50mm - Only 12.7 Megabyte free Memory ! Normal ?
I received my instinct 3 Solar 50mm today.
As delivered, only 16.4 megabytes are free.
Express refused the update to 6.28 with an error message. Not enough free memory (the update has 16.5 megabytes).
I have carried out an unpromoted reset. Express then downloaded the update file to the watch. Including the gupdate file, 96 kbytes were still free.
After the update to 6.28, I now have 12.7 megabytes of free memory with the new watch.
Is that normal? Can someone please check his free memory?
  • Update February 6, 2025:
    Garmin is investigating reports of a Garmin Express displaying an error when updating Instinct 3 Solar device. As a work around, we recommend Adding your Watch to the Garmin Connect App and update through the app. This is a software-related bug and your device does not need to be exchanged.
    Once the device is paired to the Garmin Connect App, you can manually check for updates on the watch:
    To check for updates on the device follow the steps below:
    1. Press and hold Menu
    2. Scroll up and select System
    3. Scroll up and select Software Update > Check for updates (device will request software update data)
    4. Allow device to sync with GCM a few times to see if it gets the update.
    Thank you for your patience while we investigate this report.
