Devs at GARMIN, do you test software before releasing it?
7S Pro Sapphire Solar
watch for 900USD,
and GARMIN cant do stable firmware without problems?
Why it restarts itself while navigating?
Should I go for other brand?
Or do I have to buy marq series to have something solid?
Why you treat people in this way?
  • Seems like at least this thread gets some views from Garmin... Any fixes to the sleep getting corrupted / overwritten issue?
  • Any fixes to the sleep getting corrupted / overwritten issue?
    See my comment in forums.garmin.com/.../1771685
  • OK, speaking about testing the software let me give an example of experiencing at least 5 software / UX issues in a single day when I did a large ultramarathon race.
    1) I got up very early - way before the end of the sleep window. I turned the sleep mode off manually because it is very difficult to see the screen (such the current time) when the watch is in the sleep mode. However, shortly after that it turned it back to sleep. I kept manually turning the sleep off via the controls menu, but the watch kept flipping it back. That made it difficult for me to see the time and I was really worried that it would block me from the starting the race as has been reported in this forum. One would think that it is quite reasonable that if someone manually turns the sleep mode off - they mean that, right? Has Garmin ever tested that?
    2) During the race I noticed how poor accuracy of Climb Pro was. Beginning and ends of climbs were routinely 0.1-0.2 miles off. Often I would be already climbing for more than a minute and it would tell me I am still on previous descent. I don't know what algorithm Garmin uses but it doesn't work that well for trail running. It seems to arbitrarily swallow some pretty substantial climbs, even if that is a couple hundred feet, but then it might show an almost flat part of the course as a climb even though it gains something like 45 feet in 0.6 mile. The sum of all climbs in Climb Pro is 10,800 feet. The actual total climb was 12,500 feet, so Climb Pro missed 1,700 feet out of that.
    3) Poor rendering of the elevation profile. It turned there were two fairly substantial climbs at the end of the race - very substantial when you are at 60+ miles into the race. Can you see them on this screenshot? I was looking at the remaining 2247 feet of climbing and wondering where they were. But at the end that turned to be true because the total elevation gain was about 12,500 feet.
    Also note that much off the total distance is. The course imported into Garmin Connect was 60.86 miles after importing even though the original course was closer to 63 miles. The actual distance was almost 65 miles according to the watch. During the race the watch could have updated the distance based on the progress, but it got stuck with the original distance.
    4) Up Ahead quit working towards the end of the race. There should be two more aid stations in the space where there is that blank space. That was super frustrating because I really needed that information after hours of running and a multiple hours still to go.
    5) The Stamina graph turned out to be completely useless. You'd think with all the training I did for the ultramarathon and the pattern of training, it would understand how long I can endure. But during the race, at about 7 hours the remaining stamina dropped to zero, and I kept going for another 9+ hours after that. Now, after the race the watch shows my stamina at 12+ hours, but what usage it has now?
  • I don't know what algorithm Garmin uses but it doesn't work that well for trail running. It seems to arbitrarily swallow some pretty substantial climbs
    It's only as good as the topo profile for that area. Ive been on locations where it's been absolutely spot on and others where I'll start a 20m descent right in the middle of what Garmin thinks is a continuous climb.
    I can see 2x 800ft climbs at the very end of the graphs. Are these the ones you're talking about?
    I know the stamina metrics was next to useless the moment it came out. You and only you know exactly how much you've got left in the tank before you need to quit. I had the same experience - my training only ever had me running a max of 2/3rds the ultra distance, so in the race my stamina bottoms out 2/3s into it, only to have me out down a 5:00 min/km finish hours later with apparently zero stamina. So useful!
  • 3) Poor rendering of the elevation profile. It turned there were two fairly substantial climbs at the end of the race - very substantial when you are at 60+ miles into the race. Can you see them on this screenshot
    You can see them on a large computer screen if you look carefully at the blue pixels behind those black numbers. But let me tell you that it was absolutely impossible to see those climbs on a small Fenix 7X screen, especially considering the poor contrast of the sapphire crystal.
  • You can see them on a large computer screen if you look carefully at the blue pixels behind those black numbers. But let me tell you that it was absolutely impossible to see those climbs on a small Fenix 7X screen
    Agreed. I always look at each of the climbs before starting an ultra (even if there are 25+ of them) just to get an idea of how it'll play out. No doubt it absolutely sucked to have been surprised by them at the very end.
    Garmin could also somewhat mitigate against this by showing the distance at the top rather than the bottom of the climb summary page, or by allowing us to iterate through all of the upcoming climbs during the activity, rather than statically showing the next. I believe that's a pretty well requested feature, but I'm not sure how it'd be implemented.
  • I've had Coros Vertix 2 for 30 months and I didn't even know that smart watches can crash. Now with a brand new (1 week) Fenix 7X PRO I've known about the existence of these forums, the bugs and all the nonsense I've been wasting my time on. This is my reply to you.
  • No watch is perfect - Coros Product Feedback Just because you don't have problems does not mean others do not. We know that only too well with Garmin; some have issues, other do not.
