Hi all! During the last 2 times I charged my watch I noticed that the charging screen has changed from the past. It looks like the picture below
Was it introduced in the new update (I'm on FW 9.0.0)? Or it's a setting and I can have the old back?
Settings->USB Mode
Setting to Garmin will just charge the watch and you can use it as normal, MTP mode will display the full screen charging and allow you to connect to the watch from the computer.
I don't have a standard USB charger nearby but it may be because you don't charge through the computer which will put it in Garmin mode anyway.
Garmin mode will allow you to charge the watch while in an activity which may be useful for long activities.
That's how things look when you're plugged into a wall charger. If you're seeing it when plugged into a computer, you're cable may not be connected all the way or the contacts are dirty. Maybe use something like a q-tip to clean the contacts or wiggle the cable to make sure it's seated correctly.
