Some Data Not Transferring to Strava when Using the Navigate Function
When I use the navigate function on my Fenix 5X it doesn’t transfer the elevation gain, moving time or average pace data to Strava, whereas it does when just tracking runs? It’s there a setting to choose which data fields get transferred?
Thanks
  • Maybe try again, I do this all the time with no issue like this. Moving time for sure and average pace are calculated by Strava but the elevation should be there, in Strava there is a little switch under the graph to show altitude, maybe that is switched off. You know, when you are using Navigation you also have to start an activity, Do Course is not enough for it to know to record anything.
