Baro arrow stacked flat
I cna clearly see in the baro widget that air pressure changes up and down, 2 or 3 millibars, but the arrow on watch face stays flat. Anyone else faced a similar bug, is there any way to solve it ? Or i need something like 4 plus millibars drops or ups to change the arrow direction ?
  • Great question! After thorough research, it was learned we do not have the information readily available so I have sent a request forward to get you an accurate answer to properly address your question. Once an answer has been received, I will gladly update this thread with the answer.
    Thank you for your patience. Here is your answer:
    - The arrow is made of 2, 3 hours segments. Each segment shows the trend for that period of time. So flat/up, flat/flat, down/flat are examples
    - The threshold for showing up or down arrows is approximately 2.3 millibars change over each 3 hour span
