FENIX 5 PLUS NAVIGATION THROUGH WAYPOINTS
Hello everyone,
I ve been just trying to understand if it's possible to skip a waypoint during a navigation.
I have been using the garmin for hiking, flying, and mountaneering, and usually I got different waypoints to follow or just to pass by, so if I overtake the first waypoint, how can I switch to the second one? even if not automatically, is there anything I can do to switch to the second waypoint?
I usually use the Tactics app with a preloaded GPX course, or I create a new course on the garmin fenix 5 plus itself, using different points.
Any Help? Thanks in advance
  • Any time you are running a GPX course, your watch will always take you waypoint to waypoint without an option to skip a waypoint.
    0 Former Member over 5 years ago in reply to Garmin - Chris
    ok, thanks,and is there a way to skip, fixing a proximity? I mean...If I am overflying the point, and I just pass by 1 mile for example, does it switch directly to the next? If I am not precisely over it?
  • Yep.
    But keep in mind some difference
    When using tcx or fit files for that purpose you won't use waypoints but course_points.
    Several apps & softwares including Garmin's Basecamp handle GPX/waypoints but few ones tcx/fit/course_points.
    I can't believe Garmin doesn't and I have never got an explanation of why...
    Your better chance now is to use Plotaroute with some adjustments as follow:
    Type
    Garmin
    ST3(*)
    ST3 warnings(*)
    Plota-Symbol
    Plota-Arrow
    generic
    0
    0
    none
    none
    summit
    1
    1
    Mountain
    none
    valley
    2
    2
    water
    3
    3
    Drinking Water
    none
    food
    4
    4
    Food
    none
    danger
    5
    5
    >05 danger
    Warning
    none
    left
    6
    6
    >06 left
    none
    Left
    right
    7
    7
    >07 right
    none
    Right
    straight
    8
    8
    >08 straigth
    None
    Straight on
    first_aid
    9
    9
    first_aid
    none
    fourth_category
    10
    10
    third_category
    11
    11
    second_category
    12
    12
    first_category
    13
    13
    hors_category
    14
    14
    sprint
    15
    15
    Runners
    none
    left_fork
    16
    n/a
    right_fork
    17
    n/a
    middle_fork
    18
    n/a
    slight_left
    19
    19
    >19 slight_left
    none
    Bear left
    sharp_left
    20
    20
    >20 sharp_left
    none
    sharp_left
    slight_right
    21
    21
    >21 slight_right
    none
    Bear right
    sharp_right
    22
    22
    >22 sharp_right
    none
    Sharp right
    u_turn
    23
    23
    >23 u-turn
    none
    Turn back
    segment_start
    24
    24
    >24 segment_start
    segment_end
    25
    25
    >25 segment_end
    * ST3 stands for Sporttracks , the best option but unfortunately it has  been discontinued .
    Regards,
  • I relly tried a lot to use waypoints in some way in my Fenix, but I can´t make it work.
    When I doing a route I get the directions but fields like "Time to next point" or "Km to next point" are always in blank. I tried basecamp, create a route in connect, put some POIs, but I not understand how to use it.
    With Plotaroute is possible to do that? it´s a free software?
  • You have to make your course with waypoint with Garmin Connect and then download your route as a fit-file.  Then you have to manually (read: treat your watch as an external memory) put that file under the "courses"-folder on your watch.  So don't put your course on your watch by using basecamp or "send to device" on Garmin Connect.
  • Toady I went for a run on a crouse I made with waypoints every 5km.  After about 500m I took a wrong turn and I turned back after about 50m on that wrong road (I had to run on this part only after more then 15km).  After that the name of the next waypoint was "20km" and not "5km".  It stayed like this until I really passed the 20km-point.  In my case I didn't want to skip the waypoints but I automatically did.  I made my route by uploading a KML-file on Garmin Connect and then adding waypoints.  Then I downloaded it as fit-file and manually put it on my fenix 5x.
    What would have happened if i used Plotaroute?
