Hi,
I am looking for a widget which gives the variations of the wind during the day, very important during the cycling
You are welcome to use my QuickForecast widget. Just published version is presenting window direction.
https://apps.garmin.com/us-US/apps/3509280c-2677-4d2a-bf32-249e4aee475d#0
I have two widgets that may be helpful.
DarkSky Weather Widget
Which gives you generalized data for your area, but will keep updating in the background
and
Weather Underground Widget
Which gives you data from the closest weather station, but requires getting a GPS location if you want to use the closest instead of the "last"
Thanks, but i think there is a bug. Win direction don't change
Don't see issue there, but I can cross check. Is wind direction same for the whole forecast time - 70h ? (you know - you can scroll with 'Select' buton?)
Send me your location (lat, lon) or city name.
Or check by yourself with any weather forecast provider if data are comparable.
Note - wind can be quite stable in certain weather conditions...
