Auto-Climb issues - Gradient always 0
I'm using Trail running activitie mode with Auto-Climb function switched on and the screens doesn't switch from standard to climb screen. Gradient value displayed remains to 0. Anyone else have the same issue?
    I have the same issue with the Gradient value always at zero (or close to that). But the Auto-Climb feature works as it is connected to your defined Vertical speed threshold (549m/h in my case). So as long as you move slower up than that it will not switch. Also make sure your Run Screen and Climb Screen are defined differently otherwise it will not work, obviously.
  • I reviewed my settings and good news auto-clim feature is working now but gradient value displayed is still 0 (sometime 1 or 2)
  • So I a am trying to set this feature ON but can not see where I can set the climb screen. When I go to bike ride settings, I set auto climb to on, below that I see two options one is "run screen" the other is "climb screen". Two questions, why does a run screen show up for a bike ride app. Second they are both set to show the same data, how/where do I update what is shown in the climb screen? I tried clicking it but thats not how to modify the screen. Running the latest 5.4 version. Thanks
  • "Run screen" in this case means flat or descending. You will need to set up a screen (as part of your standard series of screens) that includes your desired climbing fields as part of the Bike Settings - I add elevation (to make a 4 field screen) to my standard fields of HR, speed and cadence, but others might have different preferences. Then within the autoclimb settings, you can choose which of your existing screens you want the watch to display while climbing.
