This is what I got see yesterday while out of roads / paths. It looks like any other GPS without topo maps. Am I doing something wrong?
For reference, this is the same area in opentopomap: opentopomap.org/
A number of questions
1) Is it the standard map in the watch? (I guess so, and then that is what you get, if not downtown a city)
2) Did you deactive Worldwide DE, Basemap ? (if not do so)
3) What is your…
You could also install Garmin Basecamp - and import your map from the watch. Then you will be able to see how "detailed" your map is.
The OpenTopoMaps come with seperate contour line maps. If you activate them together with the Garmin Maps, you see both.
In the areas I used the Garmin maps so far (several wooden areas in middle and northern…
3) What is your level of map details? (should probably be high)
4) What kind of map would you expect?
Lastly when I travel to new regions - where the standard topo map is bad (like the one you showed above), i would download a free map from this site:
After some more tests and information search, seems the Europe maps doesn't include the contour lines, and they have no info about hiking routes that is not covered by OpenTopoMaps on my area. I expected to get somehting at least on pair with free maps. Pretty disappointing.
In the areas I used the Garmin maps so far (several wooden areas in middle and northern Germany and a run in UK) there is really every single path on the maps and I can see no difference to other OSMs, maybe this depends on the region. Overall the OSM-quality is extremely good in the areas I am normally running and cycling.
