I already see PacePro being available on Garmin Connect, I just played with it for my next race, an ultra marathon and unfortunately PacePro cannot calculate for longer than 15 hours :-( Some sort of limitation, who knows why? memory? etc
I do not do ultras (but would like to...), so no 15+ hour events for me. But as I am traveling I decided to test the MARQ Expedition using both a downloaded local route from GCM and add PacePro to that route. It started out nicely, with both tbt indications, correct routing on map, seemingly correct altitude curve and pace indicator. But as I took a slightly different path, and was out of route for a while, tbt was lost and the altitude curve was messed up. This is a bug I have experienced both on the MARQ and on my F5. If you do not use out of route alerts everything works fine. And in this case I did not have any alerts but the turn by turn AND the PacePro. The latter worked nice the entire session, as did navigation and the ETA screen (although a bit slow to re-calculate times as I was off/on route). But altitude and tbt was lost And these screens/data is really valuable in during trail sessions.
I will try a few more sessions and see if I can detail both bugs and behaviors a bit better.
All in all a great set of functions that have a really good use case.
