Instinct - 18.00 Public Release Candidate
Hello Instinct customers,
Please read the instructions below to update the software for your Instinct device. We've made some changes to how we deliver beta updates for our customers, so this forum post is now the primary resource for reading the change log notes – they are not available on another webpage. We look forward to your feedback!
18.00 Change Log Notes (changes since 17.50):
  • Fixed an issue preventing the device from acquiring GPS while in the Xero widget.
  • Fixed an issue causing a crash when setting heart rate alerts for an activity.
  • Fixed an issue causing Pulse Ox spot checks to not sync with Garmin Connect.
New Software versions listed are in red.
  • System Software18.00
  • BLE/ANT/SNS: 1.60
Instructions for updating software:
  • Download the .zip folder containing the update HERE
  • Connect the watch to your computer.
  • Unzip and copy the included gupdate.gcd file to the Garmin folder on your watch.
  • Disconnect the watch from the computer and it will prompt you to update software.
For any issues that you encounter, please send an email to [email protected]. In your email please include the software version, and a detailed description of your issue, along with any steps to reproduce. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Grazie mille! ora ho la 1=6, vedo se funziona meglio pure a me!
    Il fatto, é che per maggior parte degli utenti era impossibile tornare indietro, per il semplice fatto che nel foro Garmin disattivano i post anteriori e i link di download.
    Qualcuno potrebbe chiedere: e perché non ti sei tenuto i firmware anteriori? semplici, non li avevo mai avuti, perché come utente normale, ho sempre aggiornato con Garmin Express, come ti indica Garmin stessa.
    Ho scoperto dei file .zip solo dopo essere stufo degli errori e aver letto il foro Garmin.
    Grazie agli utenti che hanno condivido quei file, ho recuperato al 16 giorni fa.
    Grazie per il tuo test!
  • Ciao Luca
     ho visto che é stata rilasciata la 18.01 per correggere altimetro..!
    L'hai già provata?
  • stessi problemi della 18 purtroppo, cambiato nulla sul mio. tornato alla 16
  • ciao Luca,
    forse ho capito il problema..
    se vuoi sentiamoci
  • Io ho installato 16.50 , l'altimetro funziona molto meglio
  • Ciao, grazie per le infinite prove che hai fatto! la scorsa settimana mi é successo quello che é successo ad altri nel foro: stufo della 17.50, ho rimesso 17. Ma senza che io volessi, dopo qualche giorno si é reinstallata la 17,.50, senza darmi possibilitá di cancellare l`operazione.
    Stufo, sono passato a 16.00 e non ho nessuna intenzione diu cambiare , perché perdo solo del tempo.
    Ogni volta che torni indietro, si perdono tutte le personalizzazioni delle pagine dei widget degli sport, e sono davvero stufo di doverle creare ogni volta.
    Staro in standby, e solo quandro vedró che gli utenti saranno soddisfatti, aggiorneró. Partecipo da anni in progetti opensource, ;e parte di quel sistema dare ore del proprio tempo per segnalare bug ewtc....ma questo non é un progetto open, sono stanco di fare da cavia gratis.
    ti ringrazio per tutte le prove che hai fatto!
  • Ciao Luca
    Anch'io mi fermo e aspetto ora, sono d'accordo con te.
    Se vuoi mantenere la 16 il modo più sicuro é, una volta installata fare partire l'orologio senza associarlo al telefono.
    Bloccare gli aggiornamenti automatici in system-update
    Associare l'orologio al telefono
    Non connetterlo più al PC dove hai garmin express, altrimenti lo aggiorna comunque.
    Buona giornata!
