Hello, my garmin instinct 2 solar tactical is not recording my sleep. My battery saver is off, and I factory reset the watch, but there is no change. I am connected to Iphone 13. Any suggestions?
Well, the HR data is missing (except of a small period), and without HR the watch cannot make any sleep analysis. Do you use to turn it off, or do you use the Battery Saver feature? You can also try restarting…
At low battery, the watch may enter the Battery Saver mode automatically, and turn off the sensor, so if it was really low, it could be the reason
Could you post a screenshot of the all-day heart rate graph? Did you sleep within the bed & wake up times?
Right now I am wearing the watch on my right wrist (usually I wear watches on my left) and it is a little bit loose. I can`t tell if the sensor is lightning at night (which colour is the HR sensor?)Battery saver and stealth mode are off, I will write again in a few days, when I start wear the watch normally. Thanks fopr your help and have a great weekend ahead!
green
