Instinct Solar - 13.81 Public Beta
Hello Instinct Solar users,
We have new beta software ready for your upcoming adventures!
Please read the 'notes' and 'installation instructions' in the 'Updates and Downloads' page found in the link below. We look forward to your feedback!
Instinct Solar: https://www8.garmin.com/support/download_details.jsp?id=15394
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
13.81 Change Log Notes:
  • Fixed course navigation issue where the course would not be found again after going off course.
  • Fixed Explore Sync issue where course distance and time values would be 0.
For any issues that you encounter, please send an email to [email protected]. In your email please include the software version, and a detailed description of your issue, along with any steps to reproduce. Please note that you may not get a response to the email unless we need more information on the issue you report.
Top Replies
All Replies
  • Tengo el instint solar, he descargado el archivo, extraído el gupdate.gcd en la carpeta garmin del reloj pero no se como ejecutarlo
    If the gupdate.gcd file is compatible with your watch, it will prompt you for installing the firmware when you disonnect the USB cable, and after confirmation it will restart and report the new version number in Menu » Settings » About. If the firmware is not compatible with your watch, and you restart the watch, the gupdate.gcd will be simply deleted and the About screen will report the same old version number.
  • Entonces no será compatible... Para cuando será oficial la 13.81? Gracias
  • Para cuando será oficial la 13.81?
    As soon, as the beta version is confirmed stable, and no old or new issues need to be addressed. Typically, the beta testing phase is anything between 2 to 8 weeks, but it can, of course, differ, under specific conditions. And if you own an APAC device, it can take another month or two before the new firmware is released in the APAC version.
  • Today my Solar Instinct Tactical froze in the morning.
    I have automatic Power Save mode during my sleep time. Usually, I also set my cell phone to airplane mode during the night. Watch is set to be always paired with the phone. Today, when I woke up I noticed that my watch already turned off Power Save mode (as predicted) and probably started sync procedure. However my phone was in airplane mode so no BT communication. After some time I disabled airplane mode in my phone and few minutes later I go to another room with my Instinct (probably out of BT reach). During that time (more less, hard to tell) my Instinct froze. I noticed it about 30 minutes later according to the current time and time displayed on Instinct. Only way was to restart the watch. I am guessing that this freeze was related to failed BT sync.
    I am on 13.81 for about 3 weeks now and usually my daily routine is similar. It happened first time. That is why I am guessing that BT sync up can be a cause of those freezes.
  • Noticed that altimiter auto calibration does not work in 13.81. I have both sliders set to On for "During Activity" and "Not During Activity", but altimiter never gets calibrated. I suppose altimiter has to be calibrated as soon as I start GPS activity and watches get GPS fix. But at the moment I have to calibrate it manually before starting activity, a bit annyoing because I forget to do this.  In my area athmosperic pressure changes drastically on a day by day basis, so for the same route altimiter readings can have 80-120m difference if I don't calibrate manually before starting activity.
  • Hi there
    Can you PLEASE HELP ME -  I am stuck with the garmin instinct solar watch's course navigation issue where the course would not be found again after going off course.
    I am stuck at step 6 - Disconnect from your computer and proceed through the update. BECAUSE HOW do I PROCEED THROUGH THE UPDATE as I never get a prompt asking if I want to update???
    PLEASE help me
    Best regards
    Nita
    Instinct Solar software version 14.00 Beta
    Installation Instructions
    1. Download and unzip InstinctSolar_****Beta.zip.
    2. Place the gupdate.gcd file, found in the System_v*** folder, into the \GARMIN folder of the device.
    3. If there is a BLE_ANT_v*** folder, place the gup3468.gcd file into the \GARMIN\RemoteSW folder of the device.
    4. If there is a SensorHub_v*** folder, place the gup3467.gcd file into the \GARMIN\RemoteSW folder of the device.
    5. If there is a GPS_v*** folder, place the 006B310711.gcd file into the \GARMIN\RemoteSW folder of the device.
    6. Disconnect from your computer and proceed through the update.
    7. If you would like to revert to the last public release software, drop the gupdate.gcd file, found in the System_Backdate_v**** folder, into the \GARMIN folder of the device.
    8. NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
