Dears all,
My watches charges from fully discharged state about 2hours and half.
Is it normal?
Best Regards Martin
Sadly yes. For me the original cable was the problem since I unboxed my Garmin Instinct Solar. When I replaced it by an ebay cheap cable it charges from 0 to 100% in 2 hours. It's really incredible that a brand new cable supplied by the manufacturer is not working as expected.
It takes about three hours or a bit longer to charge the Gamin Instict Solar from Flat with the USB lead although it is best to recharge it as soon as the low battery notification comes up asking if you wanted to switch into a Low power consumption mode asking to select Yes/No though I usually select “NO” but charge it soon after using the USB lead.
