After 20.0 update battery life is terrible. It’s the same as after upgrade 15.00.
Just let me know if it works for you.
Ok, i wiil
Sorry, unfortunately it does not work. In 24h without bluetooth connection I lost 45%
Definately a firmware issue . I also went back to stock watch face and battery drain still effected
Hi, i didn't detected nothing different. Maybe i dont know how to compare files.
Im afraid of doing something wrong, then the watch will not work
Aldo For me I recharge battery yesterday evening, tomorrow at eight I went running and NOW battery is at 79%
It is quite egual to Apple Watch
My watch is still under warranty, I will send it to the after-sales service for malfunction
I think I found the source of the problem ...
It's the measurement of the heart rate. Indeed, in the previous version, the twisted LEDs, now they are lit steadily with high brightness.
I'm going to do a test without the heart rate, and see the impact.
Sorry to hear that! It sounds like the problem with fenix 5 is different than fenix 5x. I don't have any clue , sorry. Does any body here with fenix 5 have it since around FW version 12, Garmin had the same issue. You may need to create different thread for the battery problem of fenix 5.
Just go through the different folders and check the files with the same names on your device and the beta version 20.0 and compare the dates of the files. Don't do anything else, just compare the dates. The files on your device that are older than the same files on the beta are under question. Write them down and let us know. I can't suggest anything else.
thanks for all Ivan, but Garmin must be just correct the issue with a new version of the software. if not, as much to take an applewatch, if we want to do a daily charge
