So with my 3hr anytime I would get a notiification and my watch would vibrate.
For some reason, no matter what I do I cant get the 5 to vibrate on a notification, am I missing something?
I went through settings a couple times.
Not on mine... I've done several syncs this AM testing this and mine has stayed on and working through at least 6 BT syncs. I did like 4 BT syncs from the watch and 2 from inside the GC App.. The vibration stays toggled on and working. As soon as I connect to PC and sync it's turned off in Settings --> System --> Sounds
Edit to add: I am on Android so maybe the BT disabling of it is caused by iOS?
Mine is staying set as well through syncs.
For what it's worth this is a bug in Garmin's connect app. I had the exact same issue with my vivsomart HR+ except the setting in question was the backlight gesture control. After a sync sometimes the backlight gesture control would get turned off. The problem is related to their system on which is the 'master' when it comes to the settings. It's a convoluted system they have where you can set the setting on the device itself, on the website, or in the mobile app.
I think whether you are affected or not may have to do with what you had it set to when you first synced the device to their cloud. I am pretty sure I turned on vibrate before I did my first sync.
i am going to Factory reset mine and then set it up and then sync it. Are you on IOS or ANDROID?
I wouldn't do that just yet. I am on iOS and I unpaired through the phone settings, made sure vibration was turned on in the watch sound settings, then repaired through the GC app. I did multiple syncs and the vibration has remained on. Hopefully this is a permanent fix.
Well I tried this as well. As soon as it resyncs the vibration turns off right away. Strange.
Maybe the Garmin app version is different or IOS version
Mine had the same issue but I narrowed the problem down to the settings. Somehow vibration got turned off.. Not in the phone notification setting as it was turned on there but it was turned off in Settings ---> Sounds ---> Vibration
After toggling that back on, it's working again. Not sure how it got turned off unless I did so by mistake when playing around with the watch..
