From a purely logical standpoint, it doesn’t seem like there would be a universal standard relationship between watts output per calorie consumed.
					From another purely logical standpoint, it doesn't seem like there would be a universal standard relationship between heartbeats and calories consumed.
A bit late reaction:-), but it is logical. If somebody has a bigger heart and/or his heart can beat stronger (so not with more frequency, just with greater force) then it is logical that his 1 heart beat presumably requires somewhat higher energy. So calories burnt at X bpm presumably is higher than for another human being.
Is is not only heart beats. The body parameters are another factor, and then also the respiratory rate, VO₂max, and the lactate threshold play a role, among others. The method developed by Firstbeat analytics, and used in Garmin devices is described in the following whitepaper in details, though it is already a rather dated document, so it may have progressed a bit in the meantime.
EE-white-paper_1 7 6_modified_corrected 2.doc (firstbeat.com)
Sure it was exactly the same material which made me start my crusade to propose the use of this algorithm for cycling even if there is a power meter. Practically this thread is about this whitepaper and I also linked it 6 years ago in this thread https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-5-series/141473/does-garmin-use-firstbeat-calorie-calc-method-when-biking-w-a-powermeter-paired/790523#790523. Although the whitepaper was moved to the place you linked now.
You know, Trux, maybe you also should use your voice to convince Garmin that they should rely on this method even if power data is available. I did my crusade for 2-3 years, but I gave up when I saw that Garmin perpetuated their “except for a powermeter is present” approach even for Fenix 5+ . Maybe you have higher credits than me. And higher than Firstbeat itself. :-)
