Fenix 5X - 5.83 Beta Release
Hello Fenix 5X users,
We have new beta software ready for your upcoming adventures!
Please read the 'notes' and 'installation instructions' in the 'Updates and Downloads' page found in the link below. We look forward to your feedback.
Fenix 5X: http://www8.garmin.com/support/downl...s.jsp?id=11665
Please send all bug reports to [EMAIL="[email protected]"][email protected][/EMAIL], and indicate which model of the fēnix 5 series you have in the subject line.
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
5.83 Change Log Notes:
  • Added Rep Counting to the Strength activity. To enable Rep Counting, ensure that Strength Settings > Rep Counting is enabled in the Strength activity. Start the timer to automatically count reps during sets. Press the lap key to rest between sets. You can edit your last set's number of reps and weight during a rest period. Press the lap key to advance to the next set.
  • Download Strength workouts from Garmin Connect.*
  • Rep counting is also available in cardio activities when following a cardio workout downloaded from Garmin Connect.
  • Added All-Day Stress. To view the Stress widget, hold the Up key from any widget, and select Add Widget > Stress. You can view your current stress measurement on the widget page. Press the enter key to view a graph of your stress over the last four hours. Press Down to access the Four-Fold Breath relaxation timer.
  • Added support for manual calibration of the Barometer. (Settings > Sensors & Accessories > Barometer > Calibrate)
  • Added support for Hourly Alerts. (Settings > System > Time > Alerts > Hourly)
  • Added support for configuring the track color of saved activities. (Settings > Map > Track Color)
  • Improved device key handling while using Connect IQ apps.
  • Improved the course navigation icons for better visibility and contrast.
  • Fixed an issue where the device would not transition to the climb screen while using Auto Climb in certain situations.
  • Fixed an issue where the sunrise and sunset alarms were not working as expected.
  • Fixed an issue where the elevation plot for a single activity in a multisport, would display the elevation history of the entire activity.
  • Fixed an issue causing Varia UT800 Smart Headlights to periodically disconnect or power off during a ride.
  • Fixed an issue causing the Running Dynamics Pod to disconnect when using Connect IQ Apps.
  • Fixed a potential issue preventing a course from being joined when not joining it at the start.
  • Fixed a potential issue causing Personal Records to be reported inaccurately.
  • Fixed an issue where certain artifacts were being drawn on the map page while panning or zooming.
  • Fixed an issue where the device might crash when editing settings for a multisport activity during a transition.
  • Fixed an issue where the map would not refresh course data if it was edited during active navigation.
  • Fixed a potential issue where the watch may appear frozen on the watch face, when exiting out early from an active course route calculation.
  • Fixed a potential issue preventing some Training Status data from being uploaded to Garmin Connect.
*Strength workouts are currently not available via Garmin Connect. Only the capability to accept these workouts has been added. It is anticipated that this feature will be available in the near future.
  • I have not been able to sync with Garmin Connect on my MAC since the update. Instead of the full face % full charge indicator I get a little indicator at the top of the screen and no drive appearing on the MAC.
    Same for me this morning. Updated yesterday to the latest beta and today morning on a 22km run I had 4 or 5 re-connects for all the NAT+ based sensors. (HRMrun2, Tempe, Stryd).
    The graphics also show a different thing: There are some longer outages of data missing. Stryd-Data is fully present.
    Will report this to the Beta-Team as well
    I tried to turn off then on the watch but I had again some random sensor disconnect/re-connection that result in chunk of missed data in the various graphs on GC. I sent a possible bug report to the beta-team.
  • BUG: decimal digit is no longer displayed in temperature widget
    Same here - wasn't able to sync via Windows Garmin Express or even Connect Mobile - sent a Mobile sync log to the beta team and preserved the corrupted settings on a backup (pulled via Linux) if the beta team needs them. Other than that, a traumatic 'Reset To Default' fixed the issue.
    The menus in self made apps doesn't work any more. There's something wrong in the menu leveling. Only the apps developed by Garmin seems to handle the menu correctly. All other apps act strange. Is this behaviour noticed by other developers?
  • Not sure if this is limited to the latest beta, but there is a cycling map update available through Garmin Express that fails to install for me and a few other users (see my thread). I've reported this to the beta team.
  • The "around me" feature is very slow, took about 30 seconds to get the map screen. As far as I remember, was that much quicker in former fw versions? Anybody else noticed this or is it just my 5x?
    I found the offender of this issue: it is the Garmin Alpenvereinskarte together with fw 5.8x. Douple checked it with 2 Fenix 5x (for several times). If I delete the map, the around me feature is working quick/normal again. Mailed it to the fw team.
  • How does the stress score in this update relate to the stress score reported via the HRV stress app?
    Edit: tested syncing with the HRV stress app. It does work now. Thank you for fixing this.
    Cannot sync either....works every 4-6 times..... Very disturbing to make the test and then it fails to sync. And I do the test again directly.....and it fails....again. Frustrating!
    Otherwise....IT'S AWESOME! :)
