Fenix 5/5S - 4.16 Beta Release
Hello Fenix 5S/5 users,
We have new beta software ready for your upcoming adventures!
Please read the 'notes' and 'installation instructions' in the 'Updates and Downloads' page found in the link below. We look forward to your feedback.
Fenix 5S: http://www8.garmin.com/support/downl...s.jsp?id=11661
Fenix 5: http://www8.garmin.com/support/downl...s.jsp?id=11663
Please send all bug reports to [EMAIL="[email protected]"][email protected][/EMAIL], and indicate which model of the fēnix 5 series you have in the subject line.
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
4.16 Change Log Notes:
  • Fixed a potential issue where the data field page may have ghost lines when visiting the DogTracker page during an activity.
  • Fixed an issue where the gesture backlight was not working as expected during Do Not Disturb.
  • I'm seeing some oddness with the training status widget I've had this watch since the 12th and had 4 runs with an HR strap and 2 with the optical HR in that time. Is this normal? Also i think the connect mobile application is somewhat goofy as it is asking me to select which device to show training status from when I only have the one device in the application (i removed the other one). I'd like to avoid a factory reset here, but this widget changing from the default to "no status" worries me a little. ciq.forums.garmin.com/.../1232223.jpg
    Did you use the Run App to record your activity? The Trail Running App does not give you VO2 max calculations, so your training status won't be available.
  • Did you use the Run App to record your activity? The Trail Running App does not give you VO2 max calculations, so your training status won't be available.
    Yes, and i have a Vo2 max showing in the widget (well i did before rolling back to production software last night).
