Fēnix 5X – 3.41 Beta Release
Hello Fenix 5X users,
We have new beta software ready for your upcoming adventures! Please read the 'notes' and 'installation instructions' in the 'Updates and Downloads' page found in the link below. We look forward to your feedback.
Fenix 5X:http://www8.garmin.com/support/download_details.jsp?id=11665
Please send all bug reports to [email][email protected][/email], and indicate which model of the fēnix 5 series you have in the subject line.
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience. :)
3.41 Change Log Notes:
  • Added support for pre-defined Alarm labels. (Menu > Clock > Alarm Clock > Select an alarm > Label)
  • Added support for new VIRB remote commands available on Virb cameras.
  • Added support for adding widgets through the context menu. (Scroll to a widget > Menu Key)
  • Fixed an issue where the HMD configuration won’t match what is being displayed on device.
  • Fixed an issue where the activity summary could display blank lines if no heart rate was recorded during the activity.
  • Fixed an issue where certain options were missing from the context sensitive menu for CIQ widgets.
  • Fixed an issue where the activity summary information for multisport profiles only represented data from the last leg.
  • Fixed a potential issue where the device could freeze when dismissing multiple smart notifications.
  • Fixed a potential issue where the Training Effect value on post activity summary won’t match the value shown on Garmin Connect.
  • Improved the consistency of routing results when using segments with courses.
  • Fixed a potential issue where certain CIQ watchfaces could crash the device. (Requires Display 2.20)
  • Fixed an issue where the distance remaining field would not update when using segments.
  • Fixed an issue where the map wouldn’t feel responsive when the user was off-course at the beginning of a navigation.
Send all bug reports to [email][email protected][/email]
    Is the only way to install the beta to drag and drop each file into its correct folder? I installed nearly every beta on my F3 without any issues for over a year but with the 5x the first time I tried to install the beta it corrupted the watches file system and was no longer usable. I know how and where to place the files and I understand the concept and function of the file system on the watch. That being said, I had to return the watch and get a new one as the support team at Garmin could not firgure out what happened.
  • Correct me if I'm wrong but seems to me like the entire point of "no timeout" is because you care about the backlight being on MORE than saving battery. That would be like setting the GPS to 1 second recording then it automatically going into ultra trac mode to save battery
    exactly that's the point - but devs seem to have a different look on it...
  • Is your altimeter auto calibration working with fw 3.41? Mine not.
  • Still no joy from Strava live segments. Simply not triggering in 3.41. However, I'll take that malfunction over the previous behavior, which was to freak out and plead with me to get on the nearest (off segment) road or freeway.
  • I believe the backlight setting is for in activity only.when you watch face is showing it makes sense not to keep it on if you ask me,
    CW
    CW
    Agreed.
  • Pula corio
    CW
    Does not make sense to me at all! Always on is always on! I the user want to decide when the back light is on or not, if I want it to lit the watch face at night all the time despite the extra battery drain. So is it true you can no longer toggle the light to be permanently on?
    This is something the fenix 1-3 have, totally unacceptable to remove this function. Please bring permanent light toggle switch back again!:(:mad:
  • straat plaza
    I'd love to be able to tell you, but courtesy of that little gem 3.30 my MacBook no longer recognizes my watch being plugged in so I can't do beta's anymore I guess. Brilliance in action
    1) Reset your device, it'll be recognized by the mac again.
    2) Use a Windows machine to roll-back FW to previous version.
    Calm down. It hasn't been removed.
    If you want to decide when the backlight is on or off settings>system>backlight and change to your preferred preference.
    It's all working fine for me and nothing has changed.
